Power Supply Info
Currently Active Users: 2075
Discussions: 200,919, Posts: 2,379,069, Members: 246,287
Old February 6th, 2005, 05:25 PM     #31 (permalink)
jml90's Avatar
Send a message via AIM to jml90
Well it's for an sli system
When you're runnin' down my country, man
You're walkin' on the fightin' side of me
jml90 is offline   Reply With Quote
Old February 7th, 2005, 01:49 AM     #32 (permalink)
Training for Bankai
JPMiller's Avatar
Then I highly suggest a strong dual +12V offering by a well known brand like this one...
http://www.newegg.com/app/ViewProduc...104-934&depa=1
Item no# N82E16817104934
You can save a few dollars and get something better looking, and much better for that type of setup having the dual +12V rails...
Sidenote... for anyone NOT knowing what an SLI setup refers to...
http://www.tweaktown.com/document.ph...rticle&dId=740
dual PCI-Express video cards... huge power hogs...
500 watt or better PSU recommendations
Old February 7th, 2005, 02:12 AM     #33 (permalink)
GameManK's Avatar
Send a message via AIM to GameManK
another link to add to read up on
http://www.silentpcreview.com/article28-page1.html
and
http://www.silentpcreview.com/section4.html
Athlon 64 x2 3800+/2gb/asrock 939dual-sata2/gf6200/audigy2 zs plat/sonata + Asus V6J + Lenovo Ideapad U330
Kubuntu 8.10
GameManK is offline   Reply With Quote
Old February 7th, 2005, 03:26 PM     #34 (permalink)
jml90's Avatar
How about that antec? Or wha t else besides that fortron I want to keep my options open
Old February 7th, 2005, 03:33 PM     #35 (permalink)
twendanewhite's Avatar
Send a message via AIM to twendanewhite Send a message via MSN to twendanewhite Send a message via Yahoo to twendanewhite
Bump
"The Lord Cannot Look Upon Sin With The Least Degree Of Allowance" - D&C 1:31
"To GOD be all the Glory"
"Pray Oft"
twendanewhite is offline   Reply With Quote
Old February 8th, 2005, 02:22 PM     #36 (permalink)
Training for Bankai
JPMiller's Avatar
I would look for something made by the major brands I listed as good, and I think the dual +12V rails would be optimal for a system like that...
If money isnt the main concern there are some nice modular designs out now
Old February 8th, 2005, 02:41 PM     #37 (permalink)
red-dragon-69's Avatar
Send a message via MSN to red-dragon-69
umm well i was loking for a power supply turns out i have to get a special one from dell becuase other power suplys wont work on my dell 4600 cause is gona kill my motherboard as they say in the dell technical support line anyways ... i wonder if some of you might know anyohter good power supplyes that can help a dell computer and not just the one from dell .... it blows... turns out there are about 80 cases about dells 4600 that have died or die if you leave them off for like a week or so ..
red-dragon-69 is offline   Reply With Quote
Old February 8th, 2005, 03:18 PM     #38 (permalink)
Training for Bankai
JPMiller's Avatar
http://www.endpcnoise.com/cgi-bin/e/dellconverter.html
not sure if this link helps... you may need to do some research on your particular model to see what is needed... may be as simple as swapping wires or having to use an adapter...
PCPowerandCooling also sells replacement Dell PSU's here...
http://www.pcpowercooling.com/produc...ector/dell.htm
Old February 9th, 2005, 01:00 PM     #39 (permalink)
thanks for the link it help a bit ... but it came to late i have already order the suplly but i found some great info on the link so thanks.
anyways umm i gess all of you know about the ALIENWARE pc so im tryin to build one but
im loking for supply powers that are the best so maybe you guys can tell me if you know any suply power that is really really great prise doesnt matter.
Old February 9th, 2005, 01:37 PM     #40 (permalink)
Training for Bankai
JPMiller's Avatar
You mean you are building a new machine... your not talking about the Dell upgrade right?
You want to build something comparable to an Alienware machine?
power supply indi Technical Support 34 April 1st, 2009 03:19 PM
"System failed CPU test"?/CPU multiplier TuEKiD Processors, Memory, and Overclocking 8 May 6th, 2006 12:13 AM
Power Supply issues BadboyAl General Tech Discussion 9 July 22nd, 2003 12:31 PM
asus A7N8x system crashing stamenkd Technical Support 14 July 13th, 2003 10:02 PM
Help build an AMD for under $500 Mr. NoOne Technical Support 26 May 25th, 2003 04:05 AM
Is It Just Me? (2850)
Obama the Muslim (12)
Print spooler problem (12)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (33)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
