February 9th, 2005, 02:35 PM
#41 (permalink)
yea yea sorry if i said it wrong i wann build someting like the alienware. |
February 13th, 2005, 02:28 PM
#42 (permalink)
Bump for link changes/added info |
February 13th, 2005, 06:40 PM
#43 (permalink)
| Quote: |
Originally Posted by JPMiller Vantec to my knowledge are seemingly decent PSU's...
The specs look good and if you can really judge by weight, they're solid feeling...
Vantec as a whole is considered a good brand name... and I'd be highly surprised if they havent just rebadged a decent PSU from someone else...
Just for the sake of curiousity.... why so high powered?
what is it you think you will need that high a wattage for?
I have a hard time justifying spending THAT kind of Money when something just as good and still overpowered can be had for half as much... http://store.yahoo.com/amamax/psspecialxcwt420atx.html |
be surprised then. They make it ground up. And I have the Ion series 400BB. Its rock solid, heaviest PSU Ive ever seen. SUPER quiet. None this quiet I have ever used! The Vantec's are top notch for the $ no doubt.  |
February 21st, 2005, 01:44 PM
#44 (permalink)
I have built two systems with the xconnect psu and I am pleased with them both. The output is comparable to all others I have used (better in some) and the fact that is modular makes it a winner for me. Both are gaming machines and are very stable. One is a friends machine and the other is mine. RMA'd first xconnect. Does not OC well. Many reviews on the web have changed
Reason: clarity
March 3rd, 2005, 11:48 PM
#45 (permalink)
The Ultra XConnect completly failed the MaxPC stress test. I've also read user reviews of it breaking and failing. I'm going to stay away from it. Quote: |
I saw an Ultra X Connect at my local computer store the other day and I agree, it is a top quality PSU. It was very heavy and shiny
| I'm going to make a box, buff it up, and throw a million weights in it and then sell it to you as a "top quality PSU". :P |
March 4th, 2005, 12:08 AM
#46 (permalink)
haxxorpoop... you have a link to that?
I searched maximum pc's website and saw no mention of a review... |
March 4th, 2005, 11:15 AM
#47 (permalink)
The only reason the weight thing applies with PSU's is its a good sing of proper heat sinks. Light psu skimp on HS-run hot and usually fail early. Thats today with high watt pc's. I know my Vantec Ion weighs a ton, and for good reason. HUGE HS's, you can plainly see in it. Low rpm fan you cant hear at all, and it doesn't run hot. All those combined demand large HS's and weight will always, with todays psu tech be the side effect. |
March 4th, 2005, 11:52 PM
#48 (permalink)
It was in the acutal magazine. I dont know if it's leagal to scan magazine pages (arn't they protected under copyright?), but if an admin oks it, I'll show you.
Also, the issue after they published their PSU roundup, PC Power and Cooling sent MaxPC mail (which they published) detailing why modular power supplies shouldn't get points becuase they are modular (the PCPC PSUs arn't modular). They go on to explain how modulation gives less stablility in the PSU, and ultimatly, thats why you're buying a PSU in the first place. What good is a UV-lightfixtured-LEDed-OMGSOMANYLIGHTS PSU if it destroys the rest of your computer?
Xtreeme: Yes, but heatsinks != stablilty. I was just making the point that a heavy PSU != a good psu, not to mention he used the adjective "shiny" to describe this "top quality PSU".
March 5th, 2005, 12:31 AM
#49 (permalink)
Regarding the Ultra X-Connect 500 watt: I had read some good things about this PSU at the extreme overclocking forum(PSU section), however several people are RMA'ing their units due to poor voltage regulation. They have removed ALL Ultra PSU's from their recomended list. That does NOT mean it's a bad PSU, but it does mean it's a bad PSU for someone who plans to overclock.
I own 2 Antec PSU's: a Truepower 380 and a Truepower 550. The 380 is an incredible unit, as I had been running beyond what the PSU calculators said was possible. I upgraded to the Truepower 550 because I knew I was maxed and wanted room to grow. I can overclock stable again! I also hit some new FSB speeds I could never get with the 380. Admitted Antec fanboy, but with the positive experiences to justify it.
Edit: BTW; JPMiller - that's a very nice PSU information post!
March 5th, 2005, 01:14 PM
#50 (permalink)
JP: JLK basically said what MaxPC wrote: they have poor voltage regulation, which isn't a very good thing if you're going to spend ~70 bucks for a PSU. There are better choices out there for that price. |
