Power Supply Info
Currently Active Users: 1608
Discussions: 200,954, Posts: 2,379,490, Members: 246,326
Old April 15th, 2005, 03:02 AM     #71 (permalink)
Training for Bankai
JPMiller's Avatar
Nice info...
I'll have to do some research into them...
Old April 17th, 2005, 10:25 PM     #72 (permalink)
jml90's Avatar
Send a message via AIM to jml90
Ok
http://www.newegg.com/app/ViewProduc...104-968&depa=0
VS.
http://www.newegg.com/app/ViewProduc...104-155&depa=0
When you're runnin' down my country, man
You're walkin' on the fightin' side of me
jml90 is offline   Reply With Quote
Old April 18th, 2005, 12:44 AM     #73 (permalink)
Training for Bankai
JPMiller's Avatar
are you asking wich is better?
whats it powering?
do you even need units that high?
Old April 21st, 2005, 08:55 AM     #74 (permalink)
Awesome!
totally cool, this help a lot to give *assurance* I have an adequate supply
Zoltar is offline   Reply With Quote
Old May 20th, 2005, 02:30 PM     #75 (permalink)
has anyone tried or seen one of these
CAS-PS-CI GAMINGSV
Colors-it 500 Watt Gaming Power Supply
Description: Gaming 500 WATT ATX Power Supply with 120 CM Fan. 3 colors LED Light. Extra Silent. Silver Color. 6-IDE Connectors and 1-S-ATA. P4 and AMD Athlon Ready
http://www.atd-inc.com/detail.asp?PR...-CI%20GAMINGSV
md300 is offline   Reply With Quote
Old June 7th, 2005, 11:38 PM     #76 (permalink)
SoMuchAnime-SoLittleTime
EXreaction's Avatar
For any dell questions, I recently put a TT 420w in my Dimension 4600, and it basically slid in! The holes were a mm off, but that wasn't a problem for my drill. So I would say without major mods, a standard axt psu would work in the 2400, 3000, 4600, and 4700, there may be more but these are the only ones I know for sure.
My photography: Flickr
Lithium Studios - phpBB3, PHP, and Web Development
Old June 11th, 2005, 10:58 AM     #77 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
I plan to get an ePower PSU, is it Ok to use?
http://www.newegg.com/Product/Produc...82E16817101513
28 amps on 12V rail, though.
http://www.ubuntu.com
Old July 1st, 2005, 10:04 AM     #78 (permalink)
Are Codegen's PSUs good?
Georgetopouria is offline   Reply With Quote
Old July 2nd, 2005, 08:54 AM     #79 (permalink)
Training for Bankai
JPMiller's Avatar
E-Power seems to be ok as long as were not talking about the cheaper base units.
Codegen PSU's in my experience are NOT reliable.... newer units may be better than older units were, as they sometimes change manufacturers, but I wouldnt take the chance.,... get a unit from the "good" list
Old July 2nd, 2005, 07:32 PM     #80 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Well, then should I get this-
http://www.newegg.com/Product/Produc...82E16817103927
But, only 16 amps per 12V rail (2). Is that OK for a system like this-
Sempron 2800+ (754)
6600GT PCI-E
1GB of RAM
Sony Combo drive
80GB Hard Drive
Aspire Turbo case with lots of lights and 5 fans.
power supply indi Technical Support 34 April 1st, 2009 03:19 PM
"System failed CPU test"?/CPU multiplier TuEKiD Processors, Memory, and Overclocking 8 May 6th, 2006 12:13 AM
Power Supply issues BadboyAl General Tech Discussion 9 July 22nd, 2003 12:31 PM
asus A7N8x system crashing stamenkd Technical Support 14 July 13th, 2003 10:02 PM
Help build an AMD for under $500 Mr. NoOne Technical Support 26 May 25th, 2003 04:05 AM
Is It Just Me? (2946)
Print spooler problem (15)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
