Power Supply Info  | | |
July 3rd, 2005, 01:29 AM
#81 (permalink)
| | Training for Bankai
Thats MORE than enough for that system!
In fact quite a bit of overkill as well....
your only really using between 250 and 300 watts at peak, even with extras... |
July 3rd, 2005, 03:01 AM
#82 (permalink)
| | ATI 4850 FTW!
July 3rd, 2005, 03:09 AM
#83 (permalink)
| | Training for Bankai
Well generically speaking, with most NORMAL systems, yes... 18 has been the standard for awhile, however, some of todays more power hungry high tier systems with more than the standard amount of drives or extras may need more.... all depends on your configuration |
July 3rd, 2005, 03:46 PM
#84 (permalink)
| | ATI 4850 FTW!
July 3rd, 2005, 04:17 PM
#85 (permalink)
| | Training for Bankai
Thats one of my favorite manufacturers and models... |
July 3rd, 2005, 04:55 PM
#86 (permalink)
JP or anyone else wanna look at theses numbers? how are they?
Not experiencing any problems just curious if theyre ok.
Voltage Values:
CPU Core 1.62 V
+3.3 V 3.28 V
+5 V 5.08 V
+12 V 11.98 V
-12 V -12.20 V
-5 V -5.10 V
+5 V Standby 4.95 V
VBAT Battery 3.60 V |
July 3rd, 2005, 06:17 PM
#87 (permalink)
| | ATI 4850 FTW!
Excluding the 3 volt, they seem fine. 3 volt may be a little off. But, I don't think many vital components use it. |
July 4th, 2005, 09:05 PM
#88 (permalink)
| | Training for Bankai
All your rails are well within spec...
.5 either way is well within tolerance...
It can actually be a bit farther out than that in most cases due to real world conditions and the innacuracy of most sensors.. |
July 4th, 2005, 09:29 PM
#89 (permalink)
| | ATI 4850 FTW!
And, your rails need to be stable.
Granted, there will be some fluctation, but if it goes .1 up and down, I think that's bad. |
July 5th, 2005, 12:50 AM
#90 (permalink)
5% on any voltage is considered O.K. Used to be 10%! So on 12v it would be able to fuctuate .6v no problem. So in the range of 11.4v or 12.6v is ok. 3.3v can go .165 in the range of 3.465v/3.135v and be ok.
R.I.P. TKOP
