December 5th, 2004, 02:09 PM
| CD/DVD Combo Drive Won't Read Blank CDRs
I have an Artec CD/DVD combo drive which appears to work perfectly when reading CDs, CDRs, CDRWs, and DVDs.
However, it does not recognize when I have inserted blank CDRs into the drive.
How do I track down the problem?
Clayton McGow
mrwilder@atoznet.com
http://www.magicandnovelties.com
December 5th, 2004, 03:07 PM
| | Banned
I had a glitch like that ,that drove me nuts I reinstalled the software, no more problem. |
December 5th, 2004, 07:01 PM
Unfortunately, this "Artec" drive didn't come with any drivers. Which software did you reinstall? |
December 5th, 2004, 07:15 PM
go to the artec site and get the latest driver and reinstall your burning program |
December 5th, 2004, 07:48 PM
| | Banned
about to post the same message. I used nero 5.5 that came with my unit so I doubt it would do you any good.Maybe windows update will have a new driver for it. |
December 6th, 2004, 01:52 AM
I wish. The first thing I did was try to get a new windows driver for it, no such luck... and unless I'm blind, there's no XP driver for the drive listed at the artecusa.com website.
There is a driver listed for this unit, but it's for DOS. I tried installing the DOS driver, but, that driver relied on MSCDEX being available, which it is not... XP uses MSCDEXNT, AFAIK.
On the other hand, there IS a firmware update available for the drive, but, uh... the instructions aren't in great English.
I'll try reinstalling NERO (it was already screwed up when I installed NERO, but I've turned off the Windows drag and drop thing since then, so, maybe that will do something).
If this doesn't work, do you suggest I risk the firmware update, and, got any more ideas? |
