Thread: Need help
December 9th, 2004, 11:15 PM #1Junior Member
- Dec 2004
- 4
Need help
I have a Compaq Deskpro, celeron 500, 196 mb ram, and i just recently installed a new hdd. I installed win xp pro, and everything went smoothly. Windows installed beautifully, and it ran very smoothly (for a 500). However, I did all the windows updates, including SP2, and after it rebooted itself after the install, it gets past the Compaq splash screen, then a cursor comes up and there it sits. It will not boot. Anyone ever have this problem?
December 9th, 2004, 11:20 PM #2
did the system have sp1 at first?
is this a usb mouse?
i had a problem like this when i first upgraded to sp1, it has generic usb drivers so you need to uninstall your old ones first, i believe i just went into safemode to uninstall them but its been a whileHey who turned sigs on?
December 9th, 2004, 11:20 PM #3
December 9th, 2004, 11:23 PM #4
I had a problem with the sp2 locking up my system and started over up to sp1 and my computer hasn't had a problem since.One update had a driver for my GeForce card that would freeze the screen.Since then I try each update by itself before I add the next one.
December 9th, 2004, 11:49 PM #5Junior Member
- Dec 2004
- 4
I've never worked on Compaqs before, how do you boot into safe mode on this stupid thing?
December 9th, 2004, 11:50 PM #6
press f8 repetitivley when you first boot, it should go to a menu just before the windows loading screen
its the same on any windows pcHey who turned sigs on?
December 9th, 2004, 11:51 PM #7Junior Member
- Dec 2004
- 4
Thanks, I'll try that.
Edit: It just kicks me back to the damned cursor and that's it. I can't boot into safe mode, I can't boot from my windows cd, nothing.Last edited by soup_nazi; December 9th, 2004 at 11:57 PM.
December 10th, 2004, 12:37 AM #8
He may be having a memory issue if he's only got 196meg of ram . XP with service pack 2 is power hungry i think they recommend at least 256.
Just my 2 cents
December 11th, 2004, 12:18 AM #9Junior Member
- Dec 2004
- 4
I installed more RAM, and now it doesn't recognize the new 256 MB stick. What's the problem here?
December 11th, 2004, 01:08 AM #10
The clue is in your 1st post return to were it opperated fine then carefully add your updates.XPsp2 has known issues with older sofware and hardware.
No one is saying Apple has broken any laws. The just managed their cash to keep their tax payments minimized. What's wrong with that? Apple needs to learn the hard way what Microsoft learned: You...
