Thread: In Need Of Help!!! Asap
December 28th, 2004, 02:51 PM #1Member
- Dec 2004
- 79
Hi... this morning i start up my comp everything was fine till after the bootup screen then it turned black and my monitor said input not supported so i thought it was my new 256x2 ddr 400 ram because i have had problems with it... like after i put install it to my mobo after the restart it doesnt work i would have to open up my case and reinstalll the stupid ram.. so after i thought it was the ram i plug back in my old sdr ram but it had the same problem... so i m very puzzled i m on safe mode right now ... please help me asap
December 28th, 2004, 03:14 PM #2
If you are running in safe mode on that computer, it's almost definately a software problem.
You have changed the resolution and refresh rates down to minimal status right?People are like coins, there's always two sides.
December 28th, 2004, 03:33 PM #3Member
- Dec 2004
- 79
ya i did...
December 29th, 2004, 07:04 AM #4Ultimate Member
- Dec 2004
- 1,558
Best bet is to try uninstalling the video card and re-installing the drivers.
ATI drivers - http://ati.com/support/driver.html
nVidia drivers - http://nvidia.com/content/drivers/drivers.asp
If it's an integrated device, use the CD that came with your comp/mobo.
To unistall the device, go to My Computer > Properties > Hardware > Device Manager > Display Adapters. Select your card and right-click it and choose "Uninstall".
You may also want to install drivers for your monitor. If you don't know where to find drivers for your monitor, you can use Lavalys Everest (http://lavalys.com/products.php?lang=en) which will often provide a link to the driver download page.
ASAP! Help Plz! Hard Drive Copying
By MitaDC in forum Applications and Operating SystemsReplies: 10Last Post: September 1st, 2004, 10:50 PM -
To XP Warez users: Microsoft will find JOO!
By goldenbuddha in forum General Tech DiscussionReplies: 132Last Post: January 20th, 2004, 12:35 PM
Well, I watched the first six episode of Shingeki no Kyoujin finally. It was more interesting than I expected, although had about the right level of whiny loser, strong females and overzealous idiots...
Thread About Anime
