Compaq Presario 2100 screen problem
Currently Active Users: 1504
Discussions: 200,905, Posts: 2,378,901, Members: 246,275
Old January 16th, 2005, 12:41 AM   Digg it!   #1 (permalink)
Hello all, I have a problem. The screen on my laptop will work fine for a while and then red turns to yellow and black to green and were the color is there are lines of the same color going accross the screen. I have been thinking that this is a loose wire problem since it can sometimes be fixed by closing he screen and tapping on the edges or moving the screen a few times. I have the HP service center guide on this computer that tells me how to take apart the screen among other things. but i was wondering if anyone else has had this problem since all Compaq/HP customer support is done over seas and all they will ever tell you is to send it in because they know as much about computer as I know about nerosergery (and i know nothing about that).
The Goof
goofygorb is offline   Reply With Quote
Old January 16th, 2005, 02:11 AM     #2 (permalink)
Send a message via AIM to MadMan2k Send a message via MSN to MadMan2k
I have an older Compaq Armada laptop that does similar things... I don't use it much, so I just put up with it. It's pretty hard to service laptops, especially if you need new parts for them.
jonbuder.com
MadMan2k is offline   Reply With Quote
Old December 12th, 2005, 07:03 PM     #3 (permalink)
i have a problem with my screen, it trembles show i took it back to the store and they tolde me they needed 950 euros to repair it because the screen was damaged...950 euros sounds a lot if you consider that i bought it for 1150 euros...I dont know what do do. Should i buy a new screen myself? Where can i buy a new screen?
superpanos is offline   Reply With Quote
Dark Screen Compaq Presario 2100 MattHewitt Mobile Computing 9 November 27th, 2008 06:34 PM
Upgrading Pentium 2 400mhz? robertgdean86 Processors, Memory, and Overclocking 7 May 12th, 2004 03:25 PM
compaq shutting off, weird start screen martianyear Technical Support 4 April 8th, 2004 11:42 AM
networking mystery drledger Networking and Internet 4 June 26th, 2003 09:55 PM
Is It Just Me? (2809)
California Passes Anti-Flat-HDTV Le.. (38)
Fox uses old news clips to inflate .. (33)
HIS HD5770 graphic card question (14)
Foreign voltage (6)
Print spooler problem (5)
EVGA 9800 gtx help with finding a g.. (6)
Mysterious Boot manager (9)
Logitech G9 laser gaming mouse $59.95.. (2)
$5 off any item with the purchase of .. (1)
Foreign voltage (6)
What OS for a home server? (other tha.. (0)
Need hard disk drivers (3)
Asus P4G8X Mobo (0)
windows vista security holes (0)
EVGA 9800 gtx help with finding a goo.. (6)
hybernate option (2)
