Thread: xp login problem
January 16th, 2005, 01:35 AM #1Junior Member
- Jan 2005
- 6
xp login problem
i have a comptuer that runs xp pro. only one user on it.a couple of days ago i added an another acct. but now when i boot up only new user profile is available.i know this has something to do with first account created is admin but cant both profiles be available at bootup?
January 16th, 2005, 01:51 AM #2Ultimate Member
- Dec 2004
- 1,558
You can use TweakUI (on the right side) to change the logon options. Install and run TweakUI; in the menu, select "Logon". Now make sure the 'Show "username" on Welcome screen' box is checked for the appropriate accounts. Then select "Autologon" and make sure the checkbox is unchecked. This should fix the problem. If not, it gets a bit more complicated and I don't remember the process right now.
January 16th, 2005, 02:06 AM #3Junior Member
- Jan 2005
- 6
that was too EASY thanks
VPN and Drive Mapping question
By jlevene in forum Networking and InternetReplies: 34Last Post: August 22nd, 2004, 10:12 AM -
Real VNC question
By drndave2004 in forum Applications and Operating SystemsReplies: 2Last Post: March 12th, 2004, 01:59 PM -
Opera won't let me login to forums ???
By Bruneau in forum General Tech DiscussionReplies: 16Last Post: June 20th, 2003, 12:16 AM -
Mapped drives in WIN XP PRO
By skooter60 in forum Applications and Operating SystemsReplies: 9Last Post: June 18th, 2003, 06:47 PM -
Windows XP Login problem
By thegladiatorgy in forum Technical SupportReplies: 2Last Post: May 29th, 2003, 02:18 PM
Watch Star Trek Into Darkness Online. After the crew of the Enterprise find an unstoppable force of terror from within their own organization, Captain Kirk leads a manhunt to a war-zone world to...
Watch Star Trek Into Darkness...
