Results 1 to 11 of 11
    Jan 2005
    4
    ATX power supply shutting down
    I've just tried to add a maxtor diamonmax 10 drive to my PC but when I turn it on. the power supply powers down.
    If I take the new drive out, everything's fine. The PSU is 300w and I have 2 optical drive plus another HDD.
    Is this likely to be a faulty HDD or the PSU is under rated ?
    I can hear the new HDD spin up and the heads seek, but within a 4-5 seconds, it shuts down.
    any advice, greatly appreciated.
    Banned pphalan's Avatar
    Nov 2004
    BACK in the USA
    1,823
    you need a new power supply with a higher watt rating but you should list your motherboard and cpu to give an idea what load its under, how many fans also.
    Jan 2005
    4
    pphalan,
    here the listing;
    Motherborad: gigabyte GA-VAX7
    CPU: AMD XP 2000
    No case fans
    drives: 1 x deskstar 40gb hdd
    1 x LG DVD writer
    1 x HP CD writer
    hope that helps.
    If it is a power supply problem, is there any way I can verify that ?
    Ultimas w00t! Mastah... vikeor's Avatar
    Warsaw, Poland
    6,443
    well uve already verified it... when u take the new drive out all works fine. Try getting your hands on at least a 350 if not 400W PSU...
    also if its a generic PSU that could be a problem too, try getting a known brand...
    AMD Opteron 146 2.8ghz 280x10
    1GB GEIL ONE S PC3200
    DFI LanParty UT NF4 Ultra-D
    ATI X1800XT @ 700/800
    Enermax Noisetaker 485W
    BigWater SE
    Retired mostly.
    Finland
    5,150
    You can verify a power problem by unplugging your desktar hdd, plugging your maxtor (plug it to the SAME power cord you used before that did not work) and see if it turns on.
    If it doesn't it's probably a faulty wire or something. If it does, then perhaps your psu is underrated for.
    I run nobrand 350w psu with 3hdd, few case fans and loads of pci cards just fine.
    Jan 2005
    4
    Thanks for the advice, I'll get another power supply and let you know how I get on.
    Jan 2003
    Milwaukee, WI
    7,657
    Refer to this thread for Power supply help and info...
    http://www.techimo.com/forum/t124252.html
    this will help you figure out what you need and troubleshoot your current PSU
    the hard drive itself may be bad... have you checked it in another system?
    what brand is the curent PSU?
    run Eversthome to view the rail voltages...
    Nov 2004
    BACK in the USA
    1,823
    Quote Originally Posted by datam
    pphalan,
    here the listing;
    CPU: AMD XP 2000
    No case fans
    1 x LG DVD writer
    1 x HP CD writer
    hope that helps.
    try the new drive in another system or disconnect the dvd and try it
    2,949
    Personally, I would definitely try that Maxtor in a different system or, remove enough from the current system to allow more power to be available to test the PSU.
    I have used a 300 watt PSU and had more running on it than datam has and it worked great.
    Either the PSU installed now is very over rated or on its last legs before crawling into its grave, if in fact the problem turns out to be the PSU.
    Its just possible the Maxtor is defective and is putting a huge load on the current PSU.
    Jan 2005
    4
    Thanks for all the replies.
    The problem was indeed the PSU. I replaced mine with a new 500w one and it all works a treat
    Nov 2004
    53
    custompc (UK) magazine did a huge review/test on PSU's a few issues back, its well worth the read...
  1. power supply
    By indi in forum Technical Support
    Last Post: April 1st, 2009, 02:19 PM
  2. Power Supply replacement help
    By jjakobsen in forum Technical Support
    Last Post: February 4th, 2005, 08:36 AM
  3. PSU/ Mobo prob?????
    By Wombat in forum Technical Support
    Last Post: April 2nd, 2004, 07:09 PM
  4. ASUS A7M266-D power connector
    By DVNT1 in forum Motherboards
    Last Post: March 21st, 2002, 12:05 AM
