Help with first build
Currently Active Users: 2107
Discussions: 200,973, Posts: 2,379,775, Members: 246,336
Old February 10th, 2005, 08:54 PM   Digg it!   #1 (permalink)
Ok so this is what i have:
MSI Neo4 Plat SLI
Athlon 64 3500+
2 GB PC3200
XFX GeForce 6800 GT
So I had the computer put together except for the vid card.
Order that from zipzoomfly all other parts from newegg.
Finally got my vid card and installed it...my prob is im not getting any signal to my monitor. It's an old VGA and my card only has two DVI outs. Now it came with converters but i'm still wondering if I need to buy a new monitor before i can finally finish my comp or if there is another problem.
Any help will be appreciated.
Thanks in advance.
Sirjerky is offline   Reply With Quote
Old February 10th, 2005, 08:57 PM     #2 (permalink)
mazdarx7-64's Avatar
Does the PC seem to boot up just on monitor output?? also what PSU do you have?
BSOD.........
The reason why I'll be drunk tonight.
Are you a winner?
mazdarx7-64 is offline   Reply With Quote
Old February 10th, 2005, 09:02 PM     #3 (permalink)
Try another vid card if you haven't already. If you get vid...then buy a new monitor.
jdahl1979 is offline   Reply With Quote
Old February 10th, 2005, 09:22 PM     #4 (permalink)
-FMA's Avatar
Send a message via AIM to -FMA Send a message via MSN to -FMA
Originally Posted by jdahl1979
Try another vid card if you haven't already. I you get vid...then buy a new monitor.
Huh?
edit: Nvm, just re-read it and get it
You can call me Fema, thanks to brandon.
-FMA is online now   Reply With Quote
Old February 10th, 2005, 09:27 PM     #5 (permalink)
RetroEvolute's Avatar
Send a message via AIM to RetroEvolute Send a message via MSN to RetroEvolute Send a message via Yahoo to RetroEvolute
Look at your signal cable's plug, the one that goes directly into the vid card.
and if the pins are really low inside the plug, go grab some tweezers, and pull them all up to the right level again.
I was having monitor problems, and it wasn't picking up red color, etc.... SO I did this and it fixed it, it COULD be the same problem.
Intel Core 2 Quad Q6600 OCed 50% (3.6GHz) | ASUS P5K Deluxe w/ WIFI | G.Skill 4096MB (4x1024MB) RAM | MSI GTX 275 | 2x Seagate 160GB 7200.11 RAID 0
RetroEvolute is offline   Reply With Quote
Old February 10th, 2005, 09:51 PM     #6 (permalink)
lablkilz699's Avatar
Send a message via AIM to lablkilz699
"Try another vid card if you haven't already. If you get vid...then buy a new monitor."
id almost say to check with another monitor to see that the new vid card isnt actually faulty.....they can get messed up with even slight static discharge apparently...its never happened to me but i know it can happen.
Just dont go buying a 300-500 dollar lcd or whatever and then get burned when you find out the video card is actually the problem.....although getting a new LCD would be a sort of good thing disguised as a mistake i guess.
lablkilz699 is offline   Reply With Quote
Old February 11th, 2005, 02:54 AM     #7 (permalink)
Yeah i dont know if i want to spend the money on a new vid card i suppose i should have said its pci-e. Also, im using a 480W psu so it should be good enough without overclocking the card at all...I will try the plug pin thing maybe that will help...
I was going to buy a new monitor anyways this just might speed up the process. Old one has been flashing yellow lately lol.
Old February 11th, 2005, 02:59 AM     #8 (permalink)
HeadBand's Avatar
the reason they included the adapters is because it works with old monitors...they work just fine
try switching the video card to the other slot
do you have an internal speaker and are you getting any beeps out if it when you boot?
Hey who turned sigs on?
Old February 11th, 2005, 03:07 AM     #9 (permalink)
the only sounds im getting so far is from the fans
Old February 11th, 2005, 03:08 AM     #10 (permalink)
when your computer boots does it make a sound beep beep beep three times, if it does then your video card is not plugged in well in the slot
asma123 is offline   Reply With Quote
Bill O' Reilly: Good Luck Finding More Allies Chuckiechan IMO Community 63 October 6th, 2004 05:36 PM
To wait or not to wait? hav0c General Tech Discussion 4 January 6th, 2004 01:24 AM
need a little help on this PoisonousMonkey General Tech Discussion 12 June 14th, 2003 11:43 PM
How has built their own machine or bought a PC?? Stone17 General Tech Discussion 74 November 20th, 2002 12:56 PM
Charges against non-tippers dropped.. (7)
Is It Just Me? (3056)
The disrespect of Obama by Russian .. (48)
Delete an OS (16)
Nvidia GTX 260 problem (8)
Internet Lost (5)
Print spooler problem (16)
Delete an OS (16)
Multiple Restarts Required at Boot (4)
cell phone won't work (0)
Can't open Word (12)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
