Enermax 350 Watt power supply question
Currently Active Users: 2797
Discussions: 200,969, Posts: 2,379,699, Members: 246,334
Old February 19th, 2002, 10:58 PM   Digg it!   #1 (permalink)
Fur ballin
Sixpac_XP's Avatar
Thumbs up
So I tossed my (almost brand new) 300 watt Deer power supply in the dumpster and bought a Eneramx Whisper EG365P-VE power supply.
link to the product:
http://www.enermax.com.tw/products/eg-365p-vefc.htm
All I can say is WOW
My Cpu temp dropped 5oCelius and all is good.
What I would like to know is that there is a wire coming from the p/s with a termistor on the end of it. Enermax's manual is bleak at best and was wondering where I should "stick" the termistor?
I believe its a heat sensor for controlling the speeds of the fans? if so is there software i need also to control it or does it do it on its own somehow?
Thanks.
sixpac
--- Standby to receive our transmission ---
Sixpac_XP is offline   Reply With Quote
Old February 19th, 2002, 11:03 PM     #2 (permalink)
Registered User
i think that's the rpm sensor lead that goes to ine of the fan headers. does it actually have a thermister at the end?
r0l0e is offline   Reply With Quote
Old February 19th, 2002, 11:05 PM     #3 (permalink)
Fur ballin
Sixpac_XP's Avatar
yeah.. it has a 3 line power connector for the 9" fan I believe and a line with a termistor at the end of it...
(its the line on the very right of the picture)
sixpac
Old February 19th, 2002, 11:05 PM     #4 (permalink)
Registered User
if it's actually a thermal sensor, then stick it by the system temp sensor on the mobo (if it's long enough) so you have the same reading as the system temp.
edit: or you can look for the warmest spot on the mobo and stick it there.
Old February 19th, 2002, 11:07 PM     #5 (permalink)
Fur ballin
Sixpac_XP's Avatar
I guess I would only be able to glue it to the side of the heatsink because the sensor is underneath the heatsink..
I have a Abit KR7A raid with a AMD 1900+ cpu....
would that work ok?
sixpac
Old February 19th, 2002, 11:09 PM     #6 (permalink)
Registered User
what's the temp:rpm rating on the fan? do you wanna run it full speed all the time. then place it on the heat hink.
Old February 19th, 2002, 11:16 PM     #7 (permalink)
Fur ballin
Sixpac_XP's Avatar
Ok, the wires are very long so no problem... so where would the temp sensor on the motherboard for me be then?
(thanks)...
sixpac
Old February 19th, 2002, 11:18 PM     #8 (permalink)
Registered User
LOL!
you have a Abit KR7A raid you say? brb...
Old February 19th, 2002, 11:20 PM     #9 (permalink)
Fur ballin
Sixpac_XP's Avatar
thanks.. here is the quick specs on the fans:
Features
Dual Fan design of E type P.S
9cm Thermal Sensor fan: CFM=33.51, RPM = 1900, Noise Level = 27 db
8 cm fan: CFM=28.51, RPM = 2000, Noise Level = 25 db
Top quality Nippon Steel sheet metal case
Silent Operation
AMD desirable Thermal Mechanical version
Meet K7 and Intel 2.03 Version
Dual see-through cooling fan design . ( 9cm intake, 8cm exhaust)
Cable tube tied
+ 5 Vsb = 1.8A
Output over voltage protection
FM Fan Speed Monitoring
FC Fan Control by Motherboard provide real "sleeping mode" power supply (all FC models)
Noiseless and longer life
High MTBF
Extra long power leads (15")
Old February 19th, 2002, 11:23 PM     #10 (permalink)
Registered User
now we need to find out at what temp will the fan rise or do you just want to keep the fan running at full speed. BTW, the on board system temp sensor should state it on the manual.
Is It Just Me? (3033)
Forty-six years ago today (12)
The disrespect of Obama by Russian .. (47)
Internet Lost (5)
Delete an OS (9)
Nvidia GTX 260 problem (2)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
