Sudden Error...Please Help!
Currently Active Users: 2058
Discussions: 200,936, Posts: 2,379,239, Members: 246,301
Old February 16th, 2005, 04:04 AM   Digg it!   #1 (permalink)
Exclamation
Earlier My compuer was working fine.
Then after work I suddenly got an error as I booted into windows..
UNMOUNTABLE_BOOT_VOLUME
Then some stuff that doesnt matter
STOP: 0x000000ED (0x86783718, 0xc0000185, 0x00000000, 0x00000000)
I have tried going into windows recovery to try the chkdsk /r but as it tries to read the HDD it doesnt do anything for a very long time so I give up
Also When i boot into Safe mode of any kind it gives the same error. So I dont know what to do at this point.
Its a Western Digital SATA hard drive. Any help would be much apreciated
exo316 is offline   Reply With Quote
Old February 16th, 2005, 04:58 AM     #2 (permalink)
Jarhed7276's Avatar
If you bought a retail version of the hard drive it came with a cd with Data Lifeguard Tools on it. Boot from this cd (you may need to change the boot order in you bios to boot from cd) and run the diagnostic program to see if your hard drive has failed. If you didn't get a cd with your hard drive you can download a version of it from the link below. It is small enough that you can put it on a floppy disk but you will need a boot disk to boot your pc.
http://support.wdc.com/download/inde...pid=999&swid=3
Here is a link to Microsofts Knowledge Base with info on that error but the solutions don't seem to apply in your case.
http://support.microsoft.com/search/...0000ED&x=3&y=7
Jarhed7276 is offline   Reply With Quote
Old February 16th, 2005, 05:03 AM     #3 (permalink)
jrsweger's Avatar
Check this: http://www.experts-exchange.com/Oper..._21208463.html
jrsweger is offline   Reply With Quote
Windows Protection error trueman Technical Support 3 September 19th, 2004 03:20 PM
dxdllreg.exe error hathor Applications and Operating Systems 3 September 13th, 2004 03:46 PM
WinME problem DoctorReno Applications and Operating Systems 10 December 27th, 2003 11:09 PM
Comoputer Wont Start Makavali Technical Support 20 May 4th, 2003 09:10 PM
windows 7 problem (6)
Is It Just Me? (2899)
Wireless Televisions. (8)
California Passes Anti-Flat-HDTV Le.. (41)
Obama the Muslim (14)
Have you switched yet? (85)
Regular Build (4)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
Optical Audio A-B Switch (1)
