Join TechIMO for Free!
Topic: ***************************************************************** JULY 27 SUMMARY After 8 months this topic are viewed quite lots by Gateway Media Center Users. And I beleive thata was very usefull all the persons th...
Thread Tools
Currently Active Users: 2609
Discussions: 186,623, Posts: 2,223,791, Members: 229,759
Old May 10th, 2005, 12:07 PM     #41 (permalink)
This is a very good news Mr. Camlin Thanks a lot may be all people suffering from the same faillure may merge and protect their rights against Gateway Computer Company. I wish someday they will understand the power of the customers. They are joikng with us right now.
This is a very good place to help each others problem related with this product support problem.
Thank again
onder is offline   Reply With Quote
Old May 10th, 2005, 01:25 PM     #42 (permalink)
wcamlin....you stated you got your PSU from Circuit City. Which one, and does it fit into our computers? Did you get the external PSU? Which brand did you get?
thanks!
edcorpuz@hotmail.com
edcorpuz is offline   Reply With Quote
Old May 10th, 2005, 01:27 PM     #43 (permalink)
Onder... did you get the pictures of how you installed the external PSU for me?
thanks!
ed
Old May 10th, 2005, 01:36 PM     #44 (permalink)
Ed,
I will send you the pictures dont worry about
And what Wayne is bought is just an ordinary PSU and he also using PSU as externally..
Our 610 is just loosing its portabililty but anyway this works..
See ya
Old May 10th, 2005, 01:46 PM     #45 (permalink)
Thumbs up
Thanks Onder!
Old May 10th, 2005, 02:42 PM     #46 (permalink)
Here is the one I bought:
http://www.circuitcity.com/ssm/Antec...oductDetail.do
Antec 300-Watt Power Supply (25300)
I had to run the cables out through the hole where the plug used to go and I had to shave down the sides of the connectors coming out of the computer, since two jacks have to plug into one plug on the PSU. But it was very easy to figure out which goes where because all the wires were color-coded the same. I guess it is an industry standard. The PSU now sits along side the computer.
One other thing to note: This 300W PSU runs much quieter and much cooler. This should help greatly with the reliability of the rest of the components, not to mention getting all of that RF interference away from the I/O connectors.
wcamlin is offline   Reply With Quote
Old May 17th, 2005, 10:20 PM     #47 (permalink)
Originally Posted by wcamlin
Hello. I also have a 610XL Media Center that had a power supply failure just after the 1 year warranty ran out. I followed Onder's excellent instructions and replaced the PSU with a 300W PSU I got at Circuit City for $50. Gateway's solution was to charge me $400 to replace it with the same piece of crap.
I am looking into submitting a Consumer complaint with my State Attorney General and would like to know how widespread this problem is. I feel that Gateway sold a product with an obvious design flaw and should issue a recall immediately, and reimburse anyone who has already paid for a service order for this computer.
I am in the same boat - Gateway 610XL Media Center PC. Out of warranty two days ago - DOA today. Ethernet light on back of unit lights up, but computer won't boot. Sounds like this is a "1 year" power supply in this unit. I'm not giving Gateway a cent, that's for sure. No wonder they are so deep in the red.
EricKCMO is offline   Reply With Quote
Old May 20th, 2005, 04:13 PM     #48 (permalink)
Damn.. I am in the same boat as you guys.
Bought the POS and then 2 weeks after warranty expired.. bamm power supply went bad.
I wish I had found this site before...
I had to learn how to open the case and pull out the power supply.
I am contacting my Attorney General's office about this and I will post back.
I had the intern=mittent power off, then no power.. I would unplug the powersupply from the wall.. let it sit and then.. bamm it owuld work for 2-3 days..
all of a sudden it no longer worked..
I built myself a killer machine in the mean time and now have finally gotten back to this POS to fix.
I am currently working on fixing it.. hopefully I can get it done without too much trouble,
peace out..
Tank863
Visit me at http://tankweb.net
Tank863 is offline   Reply With Quote
Old June 18th, 2005, 07:39 AM     #49 (permalink)
onder,
Frist of all, thank you very much for your super helpful information
on this forum.
I have the same machine(media center 610) and yeah!!of course(?) the same
bunch of problems.
I believe that many of media center owners have almost same problems caused
by it's sloppy Psu but I have some kinda different problem which also well known
problem with this cursed machine.
"the blinking screen" problem.
I bet this is one of the most well known but not-fixable(by gateway
jerks) problem of this machine.
My machine went the gw service center twice already but still has same screen
blinking problem. The onlything that gateway jerks has done is "Replacing Video
Inverter" which doesn't make any difference.
The onlyway to make my machine "less blinks" is "jiggling it's screen couple of
times".
alright(damn.. this awesome gateway wireless-battery killing keyboard sometimes never allows me to type in capital letters. sorry about this.), my concern and question is,,,
the problem I currently have can be considered as the Psu problem which
most of you guys have?
I bet, it's not video card or video-motherboard cable connection problem cause
it sometimes blinks when hard drive accesses some data or even in normal system idling mode(ie. screen sometines blinks when internet explorer opens new window)
Hope you have some answer for my question.
Again, Thank you very much for your time and effort for all suffering
gateway users.
Regards,
- Jeff -
tuffenuff is offline   Reply With Quote
Old June 18th, 2005, 10:29 AM     #50 (permalink)
Jeff,
I am a mechanical Engineering, not Electrical, so am no expert on this, but it may be related to the lousy shielding around the PSU and its cabling. Once I moved the PSU outside of the computer, a lot of these kind of problems went away.
Wayne
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Computer Won't Boot. aje Technical Support 11 January 9th, 2005 09:04 AM
PC keeps restarting (info inside) gunstar Technical Support 11 January 3rd, 2005 07:25 PM
power supply indi Technical Support 33 June 14th, 2004 02:49 PM
Question about Newegg dr_roberts49 General Tech Discussion 4 January 4th, 2004 05:08 PM
Does my new case have enough power? drojman Technical Support 12 January 4th, 2002 06:25 PM
WHOIS info (6)
Is It Just Me? (16914)
If you were watching someone commit.. (9)
Super folding (14)
Popular Online Pc Retailers (12)
Folderchat Weekday thread (371)
Official World of Warcraft Thread!! (4505)
PSU recommendation, think mines is .. (14)
Wireless Connectivity (5)
RETTEN.EXE missing (0)
How do I find the volume label .. (4)
HOTOSHOP CS problem! (1)
Need your advice, should I cros.. (2)
RETTEN.EXE (file missng) (15)
HELP WITH FIREWALL (2)
Windows XP 32-bit on a Dell mad.. (1)
Moving Ghost server to a new ma.. (7)
Various items for sale (1)
Woot-off (5)
9800GTX 512meg (8)
