JULY 27 SUMMARY
After 8 months this topic are viewed quite lots by Gateway Media Center Users. And I beleive thata was very usefull all the persons that had same problem. So we are in the same ship
I was the first. So I liked to analyse this problem because Gateway lacks of support and now they stopped to produce it.
Now I am feeling very informatif about those machines. The 610's or DK Digital Center Exentia are all the same machines also I beleive there exists as under different brands. So main problem is our PSU. and the othere is LCD Monitor blinking.
For first problem you can buy a new replacement PSU as original for not to loose the originality and portability of the system from
appliu@gmail.com a contact from china directly it will cost some 150$. And I advise you if you buy a new orginal PSU try to not connect everything to 610 (USB, Fireware) and also If you could try to disconnect subwoofer cable from the system BECAUSE they CONSUME A LOT POWER from system so THAT MAKES FATIGUE over PSU.I beleive with a new PSU and LESS POWER Process and Device you can use it longtime.
For Second Problem please do this steps : those are the suggestion of the people I did not tried it but they say this will resolve the LCD Monitor problem :
1 - Go to your BIOS and disable Spread Spectrum Feature ??? ( I dont know
2 - Disconnect the Subwoofer cable from the system, I beleive this is related with something electromagnetic radiation. Because you can try it at your home that if you approach a haut-parleur to you monitor or television it will makes some noise over it. And some people says that this is because decreasing the POWER over the system so that PSU can better feed the monitor ??? ( I dont know
And again you can always go to my personal website at
http://www.ferahfeza.com/610X/ and see how to open 610 Media Center Computer.
I hope that new summary of this topic will help you all
Onder Y.
Hi Friends,
I have a bad story. This is a Gateway Media Center P4 2.6 Mhz HT( All-in-one compact size) PC with a special small designed power supply unit. The unit is dead last week. My warrenty is expired 10 days before and the computer is discontinued this year ( although one-year old pc ). I called Gateway they offer me ONLY to service it for 450$ + Tax +Shipment to Arizona!!!!. They dont sell me separetly the unit. ( I think this is illegal what Gateway is done ) This is funny yes.. So I decided to make my self and I dissambled the PSU and read the specification.
This is :
Delta Electronics Inc.
Model : DPS-185JB-1 A Rev:00
Input : 100-127V~/4A and 200-240~/2A at 47Hz-64Hz
Ouput : +12V / 13A
-12V / 0.2A
+5V / 14A
+5VSB / 2.5A
+3.3V / 12A
185 W
The Combine Power on +3.3V & +5V Total 100W MAX.
Made in China : )
The current situation is only +5VSB output is ok so I have an ethernet card light and my usb powered harddisk is working when I push the start button of the computer. But no way about the all other things..
So Dear Friends, I dont know about power supplies I think this is a good forum to talk about I read a very deep detailed forum about PSU here.
My solution is that to utilize an external PSU !!!! ( This will be first time maybe for this technology ) because my old dead psu was a special design and no any other that I find is like it. I will put it to roof and make an extension power cable to the inside of the computer for 20 pin and p4 pin and the others.. By the way it does not have any power cable for the harddisk ( 4 pin ) I think the power to harddisk comes from the mobo.
So let me summarize I will look for a conveniant and equivalent power supply to my computer. I dont want to defect it. I dont know what I must care about the selection ?
I make a basic research all the power unit has same voltage but different Amperage and different MAX Wattage.
Also I read in a forum that if any power unit is dead in one year this points that there is a bad quality power supply or bad selection for this mobo. May be 185 Watt is not enough I dont know.
Please give me some pointer to make this selection without damaging my mobo. Or is there any repair service for the old one ( is that also a choice for me ? )
Thank you all , any help ( I needed really )
Note : at Delta Electronics internet site there is no any information about this PSU it is a special design for Gateway..
Onder Y.
