Page 1 of 2 1 2 LastLast
Results 1 to 20 of 29
    Member CoolSax's Avatar
    Jan 2005
    West Valley City, UT
    265
    Help me with mobo!
    I baught a new mobo from newegg.com http://www.newegg.com/app/ViewProduc...131-524&depa=1
    I hooked everything up and everything looked fine. The bios was coming up great and everything but then I tried to boot from my hard drive and it would just restart. I tried another one of my hard drives and it did the same thing. One time the mobo wouldn't even start up but I waited and then it worked. What can I do to fix the problem.
    All Saxes want is peace.
    www.mediasmoothie.com
    Super F@D Folder
    Jun 2004
    5,091
    try removing the extra's from the case (high powered graphics cards..extra cd rom drives..stuff like that) how big is u'r psu? also, if you can boot from a cd try running memtest. you might also want to go into the bios and load fail safe defaults..see if that helps
    Jan 2005
    265
    Oh yeah, I tried booting from a CD and it restarted. I am running on a 420 Watt Power Supply and have 4 case fans, one hard drive, an old PCI VGA card, and a DVD Burner plugged into it. Do you think that it just isn't getting enough power.
    (AKA) Nakamura sweeper2's Avatar
    Nov 2003
    5,737
    quick question... you got a new MB... are you trying to run a HD that already has an operating system on it with your old MB drivers...?
    if it's a new MB, i would suggest a format of your HD and reinstall your operating system along with the new MB drivers....
    Ultimate Member elroy's Avatar
    Indiana
    3,774
    420 watt power supply is plenty big enough assuming it is running ok. What you have would run on a 300 watt. And what sweeper2 said.
    Benjamin Franklin
    Jan 2005
    265
    Quote Originally Posted by sweeper2
    I think you could be right with the mobo drivers. Can't I just install the new drivers on to my hard drive without having to format it?
    Indiana
    3,774
    Quote Originally Posted by CoolSax
    Depends on what version of Windows you have?
    It is different for different Windows.
    Benjamin Franklin
    Nov 2003
    5,737
    hmmm, you could try, but you might run into problems with conflicts with the old drivers...and the new ones... but if your HD won't even boot up, looks to me like there is already a compatability issue ..
    I would suggest a clean format and fresh install and then install your MB drivers etc...
    ska7ing away..... doddsy's Avatar
    Nov 2003
    a long way from home
    9,342
    sata hard drive?
    Jan 2005
    265
    Here are the full specs of my comp: IDE 80G hard drive, Windows XP Professional, PCI VGA Card, 420 Watt PSU, IDE DVD Burner, AMD Athlon 64 Socket 939 3200+
    Indiana
    3,774
    You might be able to get away with using your current Windows if you do a repair from the WinXP cd but as sweeper2 said it would be best to do a totally new installation.
    Benjamin Franklin
    Jan 2005
    265
    Once I format it should I plug my formatted hard drive into my new mobo and try installing XP on it with a bootable XP CD that I have?
    Super F@D Folder
    Jun 2004
    5,091
    if it restarts even when booting to a cd.....the drivers in windows aren't the problems
    Indiana
    3,774
    I'm thinking ......................
    Benjamin Franklin
  15. #15
    Jan 2005
    265
    Quote Originally Posted by elroy
    You should be able to format it on that board. Set the bios to boot from the cd and it will ask about saving the old Windows, tell it no and it will format in NTFS or FAT32, your choice.
    On which one the old one or the new one? Well I guess I can only do it on the old one because I tried booting from the CD and and it wouldn't on the new one.
  16. #16
    Nov 2003
    5,737
    Quote Originally Posted by sr71000
    depends on what he is booting to ... what cd? etc..
  17. #17
    Jan 2005
    265
    Windows install CD that is bootable.
  18. #18
    Jan 2005
    265
    What do you think the problem is than?
  19. #19
    Senior Member gigahertz205's Avatar
    Jan 2005
    New York
    884
    that is what i would do if i were you...
    Size 1 Rules!
  20. #20
    Super F@D Folder
    Jun 2004
    5,091
    not quite sure..but if it's restarting while booting from the cd it's almost deffinately not the windows drivers. try completely unplugging the harddrive from the computer (well..just pull the ide cable, the power can stay if u wanna leave it) and boot from a cd taht way...see if it'll boot from a cd now. could be a defective mobo
    instead of using the button on the front of the computer, take the connectors of the mobo and just use a paperclip to short the two power pins
  1. wats best 939 mobo not sli
    By beatts in forum Motherboards
    Last Post: March 22nd, 2005, 04:02 PM
  2. Help me to choose a Mobo
    By ximango in forum Motherboards
    Last Post: July 23rd, 2003, 10:03 AM
  3. Did power supply kill my mobo?
    By waferdog in forum Technical Support
    Last Post: February 28th, 2003, 07:19 PM
  4. Fried Mobo? Please advise
    By Ruahrc in forum Technical Support
    Last Post: January 21st, 2003, 09:33 AM
