Is my hard drive going to die soon?  | |
April 1st, 2005, 12:24 PM
Over the past few days I've been doing a lot of work on my computer, a lot of hard drive and processor activity. It was a little chilly this morning, around 60F, but I started my dell 8100 which I have had since mid 2001. I powered it on, and it was very quiet. Then it didn't boot, made a beeping noise . I go into the bios and no devices are listed on my 1st or 2nd ide channel. I power off and try again, same thing happens. Turn it off and finally on the third time I can hear the hard drives spinning up, and boots up like normal without any problems. Anyone have this happen to them before? |
April 1st, 2005, 12:40 PM
| | Light to Counter the Dim
It may be having problems or maybe not. It's hard to say without being there.
However, I've had drives that started to act weird (a technical term) and finally failed. What I do is backup everything and wait. I suggest you do the same.
BTW, 60 degrees is not chilly for a machine.
__________________ "The Bill of Rights is my Patriot Act." |
April 1st, 2005, 12:54 PM
| Quote: |
Originally Posted by MTAtech It may be having problems or maybe not. It's hard to say without being there.
BTW, 60 degrees is not chilly for a machine. | ^^ What he said. |
April 1st, 2005, 01:03 PM
I once had a problem like this, being you haven't had this problem before it's probably not the same. Mine turned out to be the PSU and took one of my 60gig drives down with it.
Don't buy Amd case stickers buy cyrix instead. If anyone brakes into your home your Amd will be gone, unless you have your very own cyrix stick-on
April 1st, 2005, 01:11 PM
| | ATI 4850 FTW!
It could be the PSU, since there was no indication of the drive. Since you turned it on 3 times, that might be an indicator that it might be going. My advice, get a new computer. Heck, build a new one.  |
April 1st, 2005, 01:17 PM
In fact, I recently had a PSU sputer and eventually die. One of my HD's died a month before (replaced by WD warranty). Yea, the PSU can be a cause too.
However, more the case to backup and move the data off the system. |
April 1st, 2005, 01:39 PM
For the love of Steve, Back up your data!!
20" iMac 2.16GHz / 1GB RAM / 250GB HDD / 8x DVDRW / OS 10.5
April 1st, 2005, 01:44 PM
you can do image of your hd using ghost or acronis image maker just to be on the safe side
you can download utility of maxtor website or tocows which will monitor your hd and diagnose any sort of problems
norton disk doctor perhaps |
April 1st, 2005, 02:05 PM
Hey,
First i'd try reseating the jumpers(on HDD) and swapping out the cables, reseat the power connectors.
You can try increasing the IDE delay time, if "applicable" in your BIOS. Basically delays the boot process so the drives can start spinning before the BIOS goes online....
Also if you or somone you know has experince with electronics, borrow a multilmeter and measure the 12 volt and 5 volt rails going to your HDD.
Also keep in mind that it could be the motherboard's ide controllers, before you invest any money into it. |
