restarting problems in XP
Currently Active Users: 1435
Discussions: 200,931, Posts: 2,379,161, Members: 246,297
Old April 30th, 2005, 01:18 PM   Digg it!   #1 (permalink)
Last two days when I have waked the computer was restarted. Today the keyboard was DOA, so I restart still didn't work. Took it out and put it back and it work, then the mouse wasn't working. Restarted again and now they both work.
There any logs within this OS that will tell me anything? Starting to think one of my drives might be going bad.
EDIT: Maybe it's one of these new microsoft Security Updates, can't believe there is like 5 more. It seems like I just updated last week.
Don't buy Amd case stickers buy cyrix instead. If anyone brakes into your home your Amd will be gone, unless you have your very own cyrix stick-on
joker12578 is offline   Reply With Quote
Old April 30th, 2005, 01:54 PM     #2 (permalink)
saladbarkid's Avatar
Check event viewer:
Right-Click on My Computer
Click Manage
Click Event Viewer
20" iMac 2.16GHz / 1GB RAM / 250GB HDD / 8x DVDRW / OS 10.5
saladbarkid is offline   Reply With Quote
Old April 30th, 2005, 07:02 PM     #3 (permalink)
There anyway to tell what error cause the restart?
Restarting Problems shopping98 Applications and Operating Systems 2 October 19th, 2004 08:43 PM
Restarting Problems 98 SE fated Motherboards 7 August 12th, 2004 03:28 PM
Problems with computer restarting!!! kibrisli7 Technical Support 13 June 3rd, 2004 07:18 AM
window XP restarting problems weco Motherboards 9 May 31st, 2004 10:24 PM
restarting problems with a7n8x lreid Motherboards 3 May 28th, 2003 11:29 PM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
