help Blueford "139765"  | |
May 11th, 2005, 06:04 AM
I need some help hooking up Blueford motherboard in a standerd atx case? |
May 11th, 2005, 06:20 AM
What kind of problem you got kayzar? |
May 11th, 2005, 12:37 PM
Bloeford "e139765" had no case so i am putting it in a stand atx case need help hooking up power sw hdd led reset sw power led? |
May 13th, 2005, 03:38 AM
Kayzar, I have looked for information on that motherboard but the only thing I could find out is that it is from a Dell computer(Dell 2350?). Most of the time the front panel header pins are marked as to which pins are for what. Do you know where the header pins are or is that part of the problem? |
May 15th, 2005, 01:14 AM
yes this is the problem were is the header or which one is it?
i have don't know help !! |
May 15th, 2005, 02:06 AM
| Quote: |
Originally Posted by Jarhed7276 Kayzar, I have looked for information on that motherboard but the only thing I could find out is that it is from a Dell computer(Dell 2350?). Most of the time the front panel header pins are marked as to which pins are for what. Do you know where the header pins are or is that part of the problem? | the motherboard is smiller but thier is diferent headers on my motherboard?
I don't no which one it is? |
May 15th, 2005, 02:23 AM
Kayzar, each motherboard is different so the pictures below are just to help you know what to look for. Also instead of 2 rows of pins it could be one long row.
This first picture shows the location of the pins on this motherboard. It is a common location for the pins but it doesn't necessarily mean your pins will be found here.
The second picture is a close up view to help you recognize the header pins.
Once you find the pins look on the motherboard next to the pins for connection info. It may say something like PWLED or RESET SW or IDE LED.
Edit: Does the last picture look like your motherboard?
May 17th, 2005, 12:19 PM
Thanks alot for your help |
May 17th, 2005, 06:53 PM
You're welcome. Were you able to get it connected? |
May 31st, 2005, 02:44 PM
