Results 1 to 5 of 5
    Jan 2004
    Patchogue,NY
    404
    Help with control panel
    I am having a problem in control panel. When ever I click on control panel the page opens up, but won't let me into anything there. I get a message that says
    Window Explore has encounted a problem and needs to close. I click on the detail to see what the problem is, and this is what it said...
    AppName:explorer.exe
    ModVer:0.0.0.0
    Appver:60.2800.1106
    OffSet:17614fd
    Can anyone please help me here?
    Supporting our military Bill in SD, CA's Avatar
    Oct 2002
    Camelot by the Sea
    9,979
    What OS are you using?
    If XP, have you tried a restore point to try and solve the problem.
    Then there's always the repair option available in 2K and XP.
    Bill in SD, CA
    The final legacy of the United States will be that in the end liberalism shamed & destroyed the heritage of this great nation. How sad as I see no turning back. When in Rome ..
    Super F@D Folder
    Jun 2004
    5,091
    if it's xp, click ctrl alt del and then go to processes and end explorer.exe . Then go to the applications page and run (click new process) "sfc /scannow" without the "" once it's done, run "explorer.exe" and see if that fixes it (note..this may require a windows xp cd!)
    Jan 2004
    Patchogue,NY
    404
    yes i try a restore point, and still the same. I also went into internet options to change my home page, and it won't change. I am going to try what sr said and end the process to see what happens
    Jan 2004
    Patchogue,NY
    404
    That didn't work either. Any suggestion
  1. Control panel?
    By drummerboy in forum General Tech Discussion
    Last Post: February 20th, 2005, 09:26 AM
  2. Path to Control Panel
    By Bill in SD, CA in forum General Tech Discussion
    Last Post: February 13th, 2005, 01:35 PM
  3. problems with control panel
    By goeagles in forum Applications and Operating Systems
    Last Post: June 11th, 2004, 12:11 PM
  4. User Control Panel
    By Detritus in forum Suggestion Box
    Last Post: March 1st, 2004, 10:06 AM
  5. Help! No Control Panel
    By foodbiz in forum Applications and Operating Systems
    Last Post: October 6th, 2003, 04:22 AM
