Problem with my DVD Drive :(
Currently Active Users: 1943
Discussions: 200,911, Posts: 2,378,954, Members: 246,279
Old May 25th, 2005, 11:47 AM   Digg it!   #1 (permalink)
about 2 days ago, I decided to listen to an old music album. So I put it in my DVD Drive to play the CD on my PC. Near the end of the last song, it went all funny, so I took out the CD and now my drive keeps keeps ejecting itself and when I close it, it comes out again.
The only way to stop it is to hold my finger where it ejects for about 5 attempts of ejecting before it fully stops.
The CD I used is kinda old so I don't think it will have CD protection on it. Specially not when it has a flash movie presentation.
Any help?
CD I used was "Wheatus" first album. MY Drive is also a DVD writer
gunstar is offline   Reply With Quote
Old May 25th, 2005, 12:19 PM     #2 (permalink)
Send a message via MSN to Figgienfen
What I would do, is, take the drive out of your rig, and try installing it on another rig, see if it does the same thing, if it still proceeds to do that, you have a faulty drive.
Also, doubt this is it, but check all jumpers and cables in the back.
What is the difference between genius and stupidity? Genius has limits.
Albert Einstien
Figgienfen is offline   Reply With Quote
CD-RW/DVD Combo Drive Problem NightRise420 Multimedia and Audio 5 January 16th, 2005 07:17 PM
DVD Drive Mechanical Problem? mar122999 Technical Support 2 November 10th, 2003 06:14 PM
DVD Drive Problem with windows XP? mar122999 Technical Support 3 November 10th, 2003 01:07 PM
TDK indiDVD - DVD Drive - 4X DVD+R/RW Writer $99.99 mad1 ResellerRatings Homepage Deals 2 November 9th, 2003 07:04 PM
Toshiba 8x8x8x32 CD-RW / DVD Combo Drive (new pull, drive only) $58.99 shipped John Prophet ResellerRatings Homepage Deals 0 July 24th, 2002 10:53 AM
Is It Just Me? (2821)
Why is Khalid Sheikh Mohammed even .. (7)
Foreign voltage (7)
Print spooler problem (9)
EVGA 9800 gtx help with finding a g.. (7)
windows vista security holes (3)
PSP Go bought in Japan (0)
Foreign voltage (7)
Asus P4G8X Mobo (3)
World's largest Monopoly Game using G.. (329)
EVGA 9800 gtx help with finding a goo.. (7)
Need hard disk drivers (4)
Boot Problem? (0)
Logitech G9 laser gaming mouse $59.95.. (2)
$5 off any item with the purchase of .. (1)
hybernate option (2)
