PLEASE HELP!! serious problem  | | |
June 16th, 2005, 03:40 AM
I was oc'ing in the bios. (specs in the sig) after i saved the screen went totally blank and something in the case started beeping. I turnbed i off and on, and the screen was still totally blank and the beeping sound was still there. PLEASE HELP!!!!
MSI K8N Neo4 Platinum SLI Socket 939 nForce4
Athlon 64 3200+ Venice Socket 939
CORSAIR XMS 2GB 184-Pin DDR 400 (PC 3200)
ATI x800xl PCI Express
June 16th, 2005, 04:00 AM
| | Newbie
can you reset cmos? you can find out how to reset cmos reading motherboard manual.
I miss Dimebag Darrell
June 16th, 2005, 04:02 AM
ok but do u hhave any idea wuts wrong it wont even go to the mobo mainscreen |
June 16th, 2005, 04:04 AM
| | Newbie
| Quote: |
Originally Posted by sunny22 ok but do u hhave any idea wuts wrong it wont even go to the mobo mainscreen | i don't know what wrong with it but darn, with system specs like yours, i would not attemp to overclock  |
June 16th, 2005, 04:06 AM
lol a bit too late, im going to reseat the cpu and ram also, and wut is the cmos |
June 16th, 2005, 04:13 AM
| | The Macedonian Member
| Quote: |
Originally Posted by sunny22 lol a bit too late, im going to reseat the cpu and ram also, and wut is the cmos | Its the battery on your motherboard, looks like a watch battery. On another note, you should seriously learn a bit more about oc'in before actually doing it. |
June 16th, 2005, 04:17 AM
?how should i fix that battery? wut is actually happening? does this void the warranty |
June 16th, 2005, 04:28 AM
| | icer-zerocool
I don't think you can fix the battery. Don't bother  Get a new one from a computer shop.
Try get a new RAM. RAM failure can cause the beep noise.
How many beeps are there and what BIOS are you using? The beep are error indicators. Here's a website that you must learn and know what it means: http://www.hi-tech.net/zones/help-beep.html
Knowing what type of BIOS you are using and the beep error category, you will identify the problem. Check it out.
June 16th, 2005, 01:11 PM
oc'ing can screw up the ram? |
June 16th, 2005, 01:19 PM
and who should i call for helpthe mobo company? |
