AX45-8XN w/ 2.40A CPU problem
Currently Active Users: 1462
Discussions: 200,931, Posts: 2,379,161, Members: 246,297
Old June 16th, 2005, 11:28 AM   Digg it!   #1 (permalink)
bwcc's Avatar
I have an AOpen AX45-8XN mainboard w/ BIOS rev 1.03 (latest). It has been running a 1.60A / 400 GHz P4 w/0 problems for a year now. I have a 2.40A / 533 GHz P4 that I have been trying to install, but the system will not post with that processor in it.
I read AOpen's specs on the mainboard and it will take up to a 3.06 / 533 GHz Northwood processor.
Specs on the processor are here
The board is jumperless and I have reset the BIOS to defaults after a number of tries. I have put the 1.6 back in and it's working fine and I have now tried 2 2.4 cpu's.
Am I missing something?
**Edit**
Nevermind. Solved the mystery.
bwcc is offline   Reply With Quote
Old June 17th, 2005, 10:46 PM     #2 (permalink)
Human voltmeter
DanU's Avatar
Hmm... I have an old Shuttle board that does something similar. It boots fine with a celeron 1.7 but won't boot with a P4 2.0. What did you do to resolve the problem?
Old June 18th, 2005, 02:51 PM     #3 (permalink)
bwcc's Avatar
The P4 that we received was a Prescott processor (90nm), rather than a Northwood (130nm). Sadly enough, there's no way to tell the difference from the box - you have to look up the 5 alpha-numeric code on top of the processor itself.
But that's what we get from Intel...
CPU problem and Sound problem, please help! .Cobra^ Technical Support 1 October 29th, 2004 03:28 AM
can cpu be the problem? munkeyboy123 Processors, Memory, and Overclocking 1 May 30th, 2004 09:28 PM
cpu problem? wah Processors, Memory, and Overclocking 6 July 18th, 2003 07:18 AM
Cpu or mb problem? jutah Technical Support 8 November 3rd, 2002 10:11 PM
Nero does not see Plextor 24/10/40A drive Jack Hannibal Technical Support 7 July 15th, 2002 12:08 AM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
