booting problems  | | |
June 16th, 2005, 07:56 PM
When i turn on my computer, it freezes on the motherboard main screen. This is a very recent thing, even today i was loading windows. My specs are in my signature
MSI K8N Neo4 Platinum SLI Socket 939 nForce4
Athlon 64 3200+ Venice Socket 939
CORSAIR XMS 2GB 184-Pin DDR 400 (PC 3200)
ATI x800xl PCI Express
June 16th, 2005, 08:04 PM
| | Super F@D Folder
sounds like memory to me. or a bad mobo. |
so i should reseat my ram, I'm pretty sure the mobo is fine cuz i was just using it 15 min ago with no problems |
June 16th, 2005, 08:10 PM
i just took my ram out and put it back in, it didnt help |
June 16th, 2005, 08:24 PM
| | It's the cheese guy! ¬_¬;
see how it boots when you unplug the hard drive data cables (and cd drive cables, too) |
June 16th, 2005, 08:28 PM
will it boot without a hard drive? |
June 16th, 2005, 08:33 PM
Yes, up to a point. Look out for messages about system disks, operating systems or similar. |
June 16th, 2005, 08:51 PM
Were you able to access the BIOS? |
June 16th, 2005, 09:13 PM
no,i got to that screen, but it is frozen |
June 16th, 2005, 09:15 PM
| | Super F@D Folder
reset your bios (either via the jumper or pull the battery out for a few minutes) was it overclocked?
./edit try booting with only one stick of memory in..if that dosen't work then switch the stick of memory your using if you have more than one stick. |
