Results 1 to 8 of 8
    Banned
    Apr 2005
    30
    Help.. or my computer will die :(
    I seriously think my computer will set on fire eventually i dont know heres the tempature.. and my fans are spinning so slow atm
    i havent overclocked at all, but if i declocked to like 2.5ghz would my computer reduce the tempature
    http://img13.echo.cx/img13/4164/screen15yh.jpg
    Jan 2003
    Milwaukee, WI
    7,657
    66 isnt ideal... however it isnt exactly a temp to worry about either...
    Whats your airflow situation?
    have you cleaned out all dust etc.?
    FLAC Trooper ArcticFox's Avatar
    Jan 2003
    A theater near you
    5,424
    Um... 66c?
    I'd reboot into your BIOS and check what sensor that is, if it's even correct. If your CPU is at 66c, you have a problem.
    Jun 2005
    50
    i have this problem too... AMD Athlon 64 3000+ stock heatsink and fan... its not running on the "cool and quiet" mode and the fan RPMs steadily sink till the BIOS turns the lettering red... the CPU is up to 50c now and i dont like it! what do i do?
    Jan 2003
    Milwaukee, WI
    7,657
    since when is 66C a "problem"?
    generic guidlines for temps are,....
    30's and below are ideal...
    40's are good
    50's are standard for stock with no extra cooling..
    60's are when you may want to look into extra cooling options
    80's and above are when you "need" to start worrying...
    most CPU's are rated into the 90's as safe however
    Banned
    Apr 2005
    30
    Well, the thing is when my computer gets to hot then it starts making all these squecheey noises on my speaker and freezes everything and sometimes shuts down some stuff like my server which i need 24/7
    But at 50 or so its fine, but if i leave my computer on to much it goes 60+ average.
    I got this #43 fan's Avatar
    Mar 2005
    Midwest
    5,560
    Upgrade your CPU fan and get Artic Silver 5. What CPU are you using? Underclocking will help solve the problem for a little while, until you upgrade your CPU fan to something like this-
    http://www.newegg.com/Product/Produc...82E16835128009
    Super F@D Folder
    Jun 2004
    5,091
    did you use any thermal paste or anything when you attached the heat sink fan. also...what do you mean your fans are spinning slow? they should be full speed at those temps.
  1. now it won't die
    By friedemann in forum Technical Support
    Last Post: February 6th, 2005, 12:17 PM
  2. What do you think happens when we die?
    By Hungrycookpot in forum IMO Community
    Last Post: September 11th, 2004, 10:08 PM
  3. Any help around... I am about to die
    By Tooll in forum General Gaming Discussion
    Last Post: April 8th, 2004, 02:40 PM
  4. DIE WMP9 DIE!
    By tobu in forum General Tech Discussion
    Last Post: December 15th, 2002, 06:59 PM
  5. Celeron 256 cache-on-die Vs. Pentium3 256 cache-on-die: What's the Difference
    By MegalosSkylaki in forum Processors, Memory, and Overclocking
    Last Post: May 10th, 2002, 12:17 AM
