Puter boots, but no monitor (monitor is fine though)? HELP!!!!
Currently Active Users: 1983
Discussions: 200,936, Posts: 2,379,229, Members: 246,301
Old July 3rd, 2005, 12:29 PM     #11 (permalink)
elroy's Avatar
AGP video cards are very sensitive about being properly seated. Even a tiny little bit of space or bad alignment will cause a problem. Glad you got it fixed.
Benjamin Franklin
elroy is offline   Reply With Quote
Old July 16th, 2005, 02:24 PM     #12 (permalink)
Send a message via AIM to Austine
i've been having this problem also. the old monitor i used has that no signal or standby problem, but the new flatscreen that i have works with the video card fine- why won't the old one work? when i started to have monitor problems prior to the flat screen, the monitor was working just fine. it only suddenly went into standby and has "been in a coma" ever since. what can i do? and why will the new monitor work when the old monitor doesnt and has nothing wrong with it?
Austine is offline   Reply With Quote
How close can you you put a Monitor to a Computer? To another Monitor ? MegalosSkylaki General Tech Discussion 9 June 17th, 2005 10:06 AM
gateway 2500 no video on lcd but monitor out shows on desk top monitor stonecraig Mobile Computing 0 November 13th, 2004 06:56 PM
ViaHardWare Monitor, Motherboard monitor. What to trust? ChoaticWhisper Motherboards 24 May 5th, 2003 08:38 PM
one monitor goes to sleep mode, another is fine rh71 General Tech Discussion 2 February 12th, 2003 12:34 PM
Using a laptop monitor as a normal monitor??????? br0t General Tech Discussion 7 February 13th, 2002 04:54 PM
windows 7 problem (6)
Is It Just Me? (2897)
Wireless Televisions. (8)
California Passes Anti-Flat-HDTV Le.. (41)
Obama the Muslim (14)
Modern Warfare 2 freeze (13)
CPU fan stops spinning randomly (3)
wireless user (1)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
