Results 1 to 5 of 5
Thread: Monitor problem
    Aug 2004
    Lancaster, PA
    1,550
    Monitor problem
    Alright, I'm helping someone out with a monitor problem, but I'm stumped.
    Their monitor displays an error message that says to make sure all the cables are plugged in. Well, they all are and everything's setup correctly. We've tried turning the computer off and on again, but that didn't work.
    There was a problem exactly like this that I had at a friends house years ago that I was trying to fix. The thing just wouldn't go and out of nowhere the monitor just started working again.
    Hopefully someone will provide a fix so that one is not randomly discovered.
    Ultimate Member cmptrgydv's Avatar
    Mar 2005
    MINN
    1,778
    what are the computer specs,
    that may not be the monitor,
    it could be video card
    Aug 2004
    Lancaster, PA
    1,550
    Well, his computer was working fine before. He just removed the video card and cleaned the connecting bits and put it back in and the monitor worked fine.
    Still seems pretty random for it to work at one point then need a cleaning without being touched the next.
    Mar 2005
    MINN
    1,778
    do it again, take it out,
    and put it back in,
    make sure it's in all the way
    Member just_a_nobody's Avatar
    May 2005
    356
    I agree with cmp, it sounds like you did something to the video card.
  1. Problem With new monitor
    By exo316 in forum Technical Support
    Last Post: February 19th, 2005, 05:25 AM
  2. vid card problem or monitor problem?
    By Eryk in forum General Tech Discussion
    Last Post: February 22nd, 2004, 08:35 PM
  3. monitor problem
    By dirtfarmer in forum Technical Support
    Last Post: January 28th, 2004, 08:48 AM
  4. Monitor problem
    By smkeller9 in forum General Tech Discussion
    Last Post: August 2nd, 2003, 01:21 AM
  5. Monitor Problem??
    By MikeHof in forum Graphics Cards and Displays
    Last Post: October 26th, 2002, 04:25 PM
