External Hard Disk Problem
Currently Active Users: 2241
Discussions: 200,937, Posts: 2,379,250, Members: 246,302
Old July 31st, 2005, 03:36 PM   Digg it!   #1 (permalink)
I have two external hard drives, both connected by USB. One works fine, the other has recently stopped working for no apparent reason. Not working means that it is no longer recognised as a drive by my computer.
I haven't a clue what to do or what information might be important to help solve this.
Needless to say, the disk has some important stuff on it!!
Can anyone help please?
simplyred is offline   Reply With Quote
Old July 31st, 2005, 03:40 PM     #2 (permalink)
Banned
DeathWish187's Avatar
Send a message via AIM to DeathWish187
heard any clicks or its taken any shock? consider its dieing do what you can to back up your data and try an rma
DeathWish187 is offline   Reply With Quote
Old August 1st, 2005, 09:57 PM     #3 (permalink)
No clicks. No shocks. The unit itself seems to be working, and if I uninstall the driver and reboot, the driver is reinstalled. But cannot see the drive in Windows Explorer / My Computer.
Given the above, how can I back up data? And what is a rma?
Old August 1st, 2005, 11:22 PM     #4 (permalink)
External HD
I had the same thing happen to my external HD, it would not show up as a drive, it would not do anything. Lights on, hard drive running. For the life of me I cannot remember exactly what I did, I think I unplugged the HD from the USB port, shut the computer down then plugged it back into the USB port and it came up recognized. Don't give up on it. Good luck.
Ben Humphreys is offline   Reply With Quote
Old August 2nd, 2005, 01:33 AM     #5 (permalink)
bailey's Avatar
some times usb forgets, unpluging it and then pluging it back in usally works
bailey is offline   Reply With Quote
Old August 2nd, 2005, 10:57 PM     #6 (permalink)
external hd
Did you get it back on line. Also, I would like to know what a rma is.
Old November 11th, 2005, 11:36 AM     #7 (permalink)
oyster163's Avatar
Send a message via Yahoo to oyster163
So what's your solution for this, Ben? I got the same problem and tried to figure out but...
oyster163 is offline   Reply With Quote
Old November 11th, 2005, 01:34 PM     #8 (permalink)
External hard drive
Assuming you have XP. Use the safely remove hardware feature and reinstall as a new drive. Remember these things are portable.
Old November 12th, 2005, 04:43 PM     #9 (permalink)
External HD
How did that work Oyster.
Old November 13th, 2005, 05:13 AM     #10 (permalink)
oyster163's Avatar
Sorry for my late respone, Ben.
The problem is my comp does not recognise the external hard disk, so nothing to remove... Then I tried to add a new hardware, but I failed for that...
What I am thinking is maybe some problems with my USBs on the motherboard. I may try to check the hard disk again later. But I do not have time now. I will tell you when I do that.
Thank you very much for ur fast reply & ur concern, Ben.
Maxtor external hard drive problem david747 General Tech Discussion 2 May 19th, 2005 06:04 PM
external hard drive problem david747 Technical Support 1 May 18th, 2005 05:48 PM
Very weird external USB Hard Disk behavior codetoet Technical Support 3 May 25th, 2004 01:36 AM
MDT hard disk problem raducu Storage Related 1 April 18th, 2004 10:39 AM
Dual Hard disk problem CR125Honda Storage Related 5 February 3rd, 2004 04:42 PM
Is It Just Me? (2904)
Wireless Televisions. (8)
Obama the Muslim (14)
Have you switched yet? (85)
Regular Build (4)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
Optical Audio A-B Switch (1)
