Thread: installation problems
August 1st, 2005, 09:11 PM #1Ultimate Member
- Mar 2005
- 1,789
Alright guys, yet another problem with bf2.
Just bought it today. So i installed it and I got to the screen where it says to adjust your microphone. Well i went to plug in my headset and then the realtek wizard popped up. When i got back to my chair....my mouse wouldn't move at all.
I figured i had just accidently knocked it out, looked back it was in securely.
Well anyway i brought up task manager and everything froze. I hit ctrl,alt,del 2 times after that. It didn't respond, so knowing that i would loose the installation, i regretfully did a hard restart.
Well anyway when i went to unistall it this error occured
">SetupDLL\SetupDLL.cpp(469)
pAPP:Battlefield2(TM)
pVENDOR: DICE
pGUID:*and a whole mess of numbers and letters*
$10.50.0.125
@Windows Sp2(2600) IE 6.0.2900.2180
Then when i click ok this shows up
"error code -5001"
and it has some suggestions
empty temporary internet folder
check internet connection
close backround processes
So i know the installation got messed up, and i can't unistall it through control panel...so what can i do. I already tried deleting the bf2 files in the folder, but then it still didn't work so i just restored them from the recycling bin(even though they weren't deleted from the harddrive they were out of the folder so i though it might help).
I tried re-installing before and after this, it starts up at the bf2 screen but then it says a startup file is missing
Thank you for any help
edit: the only thing i can think of now is maybe a system restore, but i have not made any points, as far as i can remember...so that wouldn't do me a favorLast edited by mateo leet-o; August 1st, 2005 at 09:22 PM.
August 2nd, 2005, 01:08 AM #2Ultimate Member
- Mar 2005
- 1,789
bump
...need....to start...fragging
August 2nd, 2005, 12:37 PM #3Ultimate Member
- Mar 2005
- 1,789
bump
August 2nd, 2005, 01:06 PM #4
You might try deleting the files in your Temp folder.
August 2nd, 2005, 01:41 PM #5Ultimate Member
- Mar 2005
- 1,789
I did it, it didn't help
I deleted all files in TEMP FOLDER, temp, and temp 14(it was empty) except for 1 file that i wasn't sure of.
"Unicows.DLL"
Microsoft layer for unicode on win9x systems
So i figured i would just move it to a new folder i created.
Still same exact problem and error
August 2nd, 2005, 02:02 PM #6
why don't you try to re-install it without worrying about uninstalling it first. at least then you will be able to successfully uninstall it if you have to. just skip the microphone setup part this time and do a computer restart instead then try to set up the microphone.
August 2nd, 2005, 02:12 PM #7Ultimate Member
- Mar 2005
- 1,789
I did try to install it again. When i click to install it it starts up and says preparing to install Battlefield 2 and shows Battlefield 2 in big letters...but then it just stops and does nothing. The Battlefield 2 picture also dissapears, and I'm left staring blankly at my desktop
Originally Posted by Iturea
edit:here is a pic, after i deleted all the bf2 stuff
everything i could find at leastLast edited by mateo leet-o; August 2nd, 2005 at 06:00 PM.
August 2nd, 2005, 08:10 PM #8Ultimate Member
- Mar 2005
- 1,789
bump
August 2nd, 2005, 09:03 PM #9
August 3rd, 2005, 08:19 PM #10Ultimate Member
- Mar 2005
- 1,789
I read that and this is what i did. Maybe i read it wrong?
Originally Posted by meese
Tried to uninstall restarted through windows(not physically pushing the button on my case) and then tried to uninstall again. Same problem. I tried the same way but i powered off by pressing the restart button on my case. Same thing.
Then I tried both ways of restarting but this time trying to reinstall.
Nothing worked.
Thanks for the link anyway Meese
Maybe I am reading it wrong, I tried at 1:30 in the morning and I tried when I had drops in my eyes to enlarge my pupils. My eyes got irritated when i looked at the screen.
Well i read and try again.
XP installation problems!
By kyngnothing in forum Applications and Operating SystemsReplies: 7Last Post: October 5th, 2004, 02:17 AM -
SUSE Installation Problems - Please Help!!!
By jimmycheesecake in forum Linux and UnixReplies: 14Last Post: September 10th, 2004, 10:54 AM -
OS installation problems
By thewebel in forum General Tech DiscussionReplies: 10Last Post: May 11th, 2003, 07:20 PM -
Mandrake 9.0 Installation Problems: X-Server, GUI Problems?
By chromelocust in forum Technical SupportReplies: 2Last Post: March 21st, 2003, 03:50 AM -
Applications Installation Problems..need help.
By Zotzmein in forum Technical SupportReplies: 7Last Post: March 4th, 2003, 12:54 AM
Are you guys looking for the awesome full day entertainment here are some options for you take a look. Teen Wolf Season 3 Episode 3 Chopped Season 16 Episode 6 The Bachelorette Season 9 Episode...
The Bachelorette Season 9 Episode 4
