Start up problem
Currently Active Users: 2624
Discussions: 201,002, Posts: 2,380,053, Members: 246,371
Old August 15th, 2005, 01:03 PM   Digg it!   #1 (permalink)
Start up problem
I have a Dell 8100 with Windows Me. My computer froze up so I shut it down. When I started it back up it, it looked like everything went okay but I ended up with only the screensaver. No desktop icons so I look in task manager and the only thing showing up was Nprotect (norton antivirus). I shut it down and started up several times but no go. I tired starting up in Safe mode and the only difference is task manager is then empty, no Nprotect. Does anyone no what's causing the problem?
ConKnee is offline   Reply With Quote
Old August 15th, 2005, 01:16 PM     #2 (permalink)
Are you still under the Dell support time period?
pariscope is offline   Reply With Quote
Old August 15th, 2005, 01:34 PM     #3 (permalink)
bwcc's Avatar
Doubtful that its under warranty, being its an 8100.
By screensaver, Im guessing you mean background. This sounds like explorer.exe is having difficulty loading. I would check the harddrive and make sure it is sound (scandisk or hdd utility). If that does not help, then Windows will need to be repaired.
You can try editing the system.ini file and change the shell= to winfile.exe and boot up that way.
I also found this on Gateway's website - it may give you some other options to try as well.
http://support.gateway.com/s/issues/2-1330790523.shtml
And welcome to Techimo!
bwcc is offline   Reply With Quote
Start up bar problem... NightRise420 Technical Support 2 February 22nd, 2005 10:04 PM
Help With Start Menu Problem maximus01can Applications and Operating Systems 3 September 6th, 2004 05:27 PM
$5.00 Start up problem XP Derek79602+ Applications and Operating Systems 25 February 14th, 2004 04:01 PM
Sound Problem + start up error box IceWarrior Technical Support 3 October 5th, 2003 04:29 PM
Problem installing XP from start up C230xMatt Technical Support 15 June 26th, 2003 02:19 AM
Is It Just Me? (3128)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
