Hi all,
I' hoping someone can come up with a suggestion. I've just updated the BIOS on my Shuttle and installed an intel 3.2Ghz processor. Everything works, except the fans are at full throttle. When I had a 2.4Ghz Celeron, it all worked fine, but now the fans never change speed and is very noisy. I've checked all the cables, and they are all connected.
I've edited the BIOS, and set the fan speeds etc. but still to no avail. I even installedthe XPC tools, and the temp. is about 46 degrees, which is way less than the default 68 degrees.
Does anyone have any idea?
Thanks in advance
Ray
