SATA Controller problems
Currently Active Users: 2683
Discussions: 200,966, Posts: 2,379,635, Members: 246,332
Old September 22nd, 2005, 09:58 PM   Digg it!   #1 (permalink)
Greetings! I ran across this message board whilst investigating the problem I'm having, and I found a thread that was, well, similar to, but not exactly what I'm having trouble with.
Here's my issue.
I have an ASUS A7N8X mobo. Attached were an 80GB PATA drive (for the OS), and a 250GB SATA drive (for files). I wanted more storage, and bought two 300GB SATA drives. The problem is that my mobo has two SATA connections on it. I worked out the math in my head, and realized I needed another port
So I bought the Syba card that I think the person in that thread bought. Probably not a great card, but I'm not doing RAID or running anything too intensive through it. Just storing files.
The problem is this. I can have one, two, or no drives connected to my motherboard and I boot fine. The second any drive whatsoever is attached to the Syba card, my machine doesn't boot past the drive check for the two controllers. It will indeed check both controllers, and accurately report any drive configuration I hook up to it, but if there is any drive attached to the card, that's where the boot process stops.
Naturally, I'm eager to add another 300GB to my system. I currently have only added one drive, and another is sitting useless on my desk.
I implore you good people. Do you have any ideas?
Dignan17 is offline   Reply With Quote
Old September 24th, 2005, 04:33 PM     #2 (permalink)
No ideas?
SATA and IDE controller bridged. Bizkitkid2001 Storage Related 81 August 21st, 2005 12:54 AM
Motherboard SATA Controller Problems!!! rmsx882x Motherboards 0 February 18th, 2005 09:07 AM
Sata PCI controller fresh install [dnb]junglist Technical Support 1 December 14th, 2004 09:49 PM
USB 2.0 controller problems kenboyles72 Technical Support 1 October 2nd, 2004 04:01 AM
Controller problems in arcade emus PuddingShorts General Gaming Discussion 1 April 16th, 2003 04:15 AM
Is It Just Me? (3012)
Forty-six years ago today (7)
Internet Lost (5)
windows vista security holes (15)
Help getting around port 80 for camer.. (4)
Open With ..... Win7 (2)
Internet Lost (5)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
