Thread: Help! Hard Disk Trouble
October 6th, 2005, 04:50 PM #1Junior Member
- Oct 2005
- 1
I'm running a 120GB SATA hard disk (i can't remember the make) on a Aopen motherboard.
Whenever I boot the computer it runs CHKDSK.
While running CHKDSK it finds corrupt attribute records and several unreadable file record segments. Then it deletes some corrupt attribute records and corrects errors in indexes.
After doing this a blue screen appears and says:
DRIVER_IRQL_NOT_LESS_OR_EQUAL
Technical Information
Stop: 0x000000D1 (0x00000028, 0x00000006, 0x00000000, 0xF87CCC1A)
ulsata.sys -Address F87CCC1A base at F87C6000, Datestamp 3d2a7380
Windows also takes much longer to do anything and I am unable to delete anything from my hard disk, windows displays an error message saying it is unable to delete because the directory is corrupt or unreadable.
Any help would be greatly appreciated.
October 9th, 2005, 12:10 AM #2Member
- Jun 2005
- 470
i am about to go to bed, hehe, so didnt have time to actually research those lines of error code but a quick suggestion if i'm right is thay .sys file appears to be a driver for a controller card that the HDD is on or a driver for the controller on the mobo. In whatever case, my quick guess is it's corrupted.
If you have not updated the driver within the last 30days or so, reinstall driver. IF it is a very recent driver, roll back driver(winxp) or remove driver and install either a newer one or older one.
For a quick guess, it appears to be a driver problem but if this doesnt resolve problem, I will actually research it for you.
October 9th, 2005, 12:22 AM #3
October 9th, 2005, 02:25 AM #4
October 10th, 2005, 05:20 AM #5
Can you boot in safe mode? It loads windows with limited drivers so maybe that might help. I have encountered this problem before ande booting in safe mode worked. It does demend on the driver that is missing/currupt.
hard drive trouble
By pacfreestyle2005 in forum General Tech DiscussionReplies: 9Last Post: June 27th, 2004, 03:04 AM -
Hard Drive Trouble
By Immortal55 in forum Storage RelatedReplies: 2Last Post: June 17th, 2004, 01:49 AM -
hard drive trouble
By pestengpasig in forum Storage RelatedReplies: 4Last Post: October 22nd, 2003, 03:29 AM -
Having disk trouble
By GRAEME W in forum Technical SupportReplies: 2Last Post: September 9th, 2003, 05:05 PM -
Trouble with my new Hard Drive
By CraigK in forum Technical SupportReplies: 4Last Post: March 24th, 2003, 04:15 PM
While it serves the purpose to fund government, it's also a way for politicians to engineer the economy. As you said, do away with tax breaks and make sure the playing field is level for all...
