Multimedia Audio Controller PROBLEMS...help me solving it
Currently Active Users: 1446
Discussions: 200,931, Posts: 2,379,161, Members: 246,297
Old October 10th, 2005, 06:15 AM   Digg it!   #1 (permalink)
My sound card is not working .. everything looks okay in Device Manager except for the entry in 'other devices' Multimedia Sound Controller' which is flagged as not working. When I try to set any audio properties 'it' tells me I do not have this device installed - no audio device. Help please if you can ..
qewani is offline   Reply With Quote
Old October 10th, 2005, 01:11 PM     #2 (permalink)
Human voltmeter
DanU's Avatar
Is this a new build? It looks like you need to install drivers for your soundcard. Your soundcard should have come with a driver CD. If your sound is integrated into the motherboard then the driver should be on the CD that came with your motherboard.
Old October 12th, 2005, 06:49 AM     #3 (permalink)
i don't have any sound card diver cd.....maybe i have lost it ....so can any one help me get the drive from the intenet
by the way i have opened the CPU and i had looked on the sound card it is a VIA company sound card and its number is 8237
please help me finding the sound card driver
Old October 12th, 2005, 08:19 AM     #4 (permalink)
quickoldcar's Avatar
Send a message via AIM to quickoldcar
Go to driverguide.com they will have the driver or any others you need in the future. I think you have to put your email address there and register--but well worth the little effort.
quickoldcar is offline   Reply With Quote
Old October 12th, 2005, 05:38 PM     #5 (permalink)
Human voltmeter
DanU's Avatar
VIA 8237 is the southbridge controller on the motherboard which also has integrated audio. You need to download the VIA Vinyl audio drivers from www.via.com.tw
Old October 14th, 2005, 06:50 AM     #6 (permalink)
thanks DanU
i have found the diver and every thing is ok now
(*_*)
Old October 14th, 2005, 06:08 PM     #7 (permalink)
Human voltmeter
DanU's Avatar
Glad to have helped!
ti 83 solving newcomp Webmastering and Programming 11 April 18th, 2008 09:24 AM
Need drive "PCI Multimedia Audio Device" Guimaraes Motherboards 8 January 31st, 2008 11:41 PM
Saa TV card & Multimedia dideo controller pirji Multimedia and Audio 2 September 27th, 2005 06:34 PM
PLEASE HELP (PCI multimedia audio device) samualsiedler Multimedia and Audio 4 August 10th, 2005 06:03 AM
Recall/Repair Audio Video Controller/Amplifiers mad1 General Tech Discussion 1 October 31st, 2003 05:01 AM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
