Problems with Voltage
Currently Active Users: 2686
Discussions: 201,002, Posts: 2,380,049, Members: 246,371
Old October 22nd, 2005, 11:29 AM   Digg it!   #1 (permalink)
Send a message via AIM to Slayertime Send a message via MSN to Slayertime Send a message via Yahoo to Slayertime
I noticed when i downloaded Everest that my -12v is WAY off its +2. Is this bad wiring on my part did i mess up something? Please i would like to get this fixed.
This could explain also why i have had problems with my PC lately.
AMD Athlon 64 FX-53
Asus SK8V Mobo
120 gig HD
160 Gig HD
1024 gig Corsair XMS Extreme Edition Low Latency
Vision Tek ATI X800XT PE
Audigy 2 ZS
Slayertime is offline   Reply With Quote
Old October 22nd, 2005, 12:22 PM     #2 (permalink)
elroy's Avatar
I believe this is common for the -12 volt to show weird readings.
I would be more concerned about the +12 volt. 11.37 is to low. Usually + or - 5% is ok. On the +12 that would be a minimum of 11.4 I would check the readings in the bios to see if they are different.
Benjamin Franklin
elroy is offline   Reply With Quote
Old October 22nd, 2005, 12:34 PM     #3 (permalink)
Then why on my other built computers they are normal
Voltage Problems Slayertime General Tech Discussion 12 June 14th, 2005 02:07 PM
voltage bobaraba General Tech Discussion 8 February 27th, 2005 12:21 PM
What voltage??? shadrach84 Processors, Memory, and Overclocking 4 January 21st, 2004 09:25 AM
Voltage Tazman Technical Support 3 April 27th, 2003 11:30 AM
AAAAAAAHHHH!!!! Heat and Voltage problems BlingBling Technical Support 9 September 8th, 2002 04:22 PM
Is It Just Me? (3126)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
