Memory problem, please help!?
Currently Active Users: 1484
Discussions: 200,931, Posts: 2,379,162, Members: 246,297
Old October 25th, 2005, 02:32 PM   Digg it!   #1 (permalink)
Hi all,
I have a DFI lanparty Nforce4 ultra D mobo, I orginally put in Hynix 2x256mb pc3200 of ram dual channel memory, and all has worked great thus far, I recently bought 2x512mb of Samsung memory pc3200 and added it to have a total of 1.5gb of ram, at first my system wouldn't boot up, it would just stay on the Nforce 4 logo screen, then I tried taking the Hynix ram out and just using the Samsung, I got a blank screen with no booting up, (no Nforce4 logo) I figured well maybe the ram is a bit too cold (I had recently just picked it up at a purolator office), so finally I tired using all the ram like I had originally done and it booted up, but I'd have to restart the computer like 2 or 3 times because it wouldn't get past the Nforce 4 logo, when it did finally boot up to windows I went into system properties it says I still only have 512mb of ram, when I should have 1.5gb....what's up with that, and why isn't my pc booting up with just the Samsung memory in by itself, it's brand new ram!?!?
optinox is offline   Reply With Quote
Old October 25th, 2005, 02:36 PM     #2 (permalink)
Megalomaniacal
SoloCamo's Avatar
Send a message via AIM to SoloCamo
there is always the possbility that the ram is bad.
Nonetheless running 4 sticks of ram on amd64 based mobo's have been known to cause problems, such as extremely high timings, incorrect speeds (downlclocking)... II haven't heard of this though.
Do you have the latest bios, drivers... etc.?
oh and for the record, the COLDER the parts run, the BETTER they perform
SoloCamo is offline   Reply With Quote
Old October 25th, 2005, 03:01 PM     #3 (permalink)
Millwright
stroyal's Avatar
Like Solo said cold is good.
Sounds like the Samsung is bad or incompatable.
Try the Samsung one stick at a time to see if maybe only one stick is bad.
stroyal is offline   Reply With Quote
Memory problem Eagle19 Processors, Memory, and Overclocking 16 October 2nd, 2005 01:14 AM
Memory problem erico30 Technical Support 4 September 3rd, 2004 03:29 PM
Memory problem after format & partion problem soulja Technical Support 3 June 2nd, 2003 10:59 PM
Memory Problem Terminal23 Motherboards 2 March 6th, 2003 06:29 PM
MEMORY PROBLEM!!! FlyingHamster Technical Support 4 April 18th, 2002 12:56 AM
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
