MS Outlook Formatting Problem
Currently Active Users: 1728
Discussions: 200,957, Posts: 2,379,506, Members: 246,328
Old December 21st, 2005, 11:53 PM   Digg it!   #1 (permalink)
I have Win XP, Office XP and having formatting issue with MS Outlook. I have setup "Computer in this message format" to "html" in Tools --> Options --> Mail format. I have an html signature which come out fine when I create a new message but when I reply to any existing message no matter which format they are in (mostly in html format), the format changes to plain text instead of html and the signature comes out all messed up as it clears formatting. How can I keep formatting to stays in html format for all new, forward and reply messages. Thanks
Loafer72 is offline   Reply With Quote
Old December 22nd, 2005, 07:27 AM     #2 (permalink)
Geforce's Avatar
I know what you mean. All I tend to do is just stick the setting to Plain Text.
Seems to be less hassle that way
IT Noob
Geforce is offline   Reply With Quote
Old December 22nd, 2005, 06:54 PM     #3 (permalink)
bwcc's Avatar
Forwarding and replying to messages will automatically take the form of the original email. If you receive an email from someone that is in plain-text, you will reply or forward that message in plain text as well.
I would guess your solution would be to remove your auto-sig on forwards and replies. Then when forwarding or replying, choose the HTML format from the Format dropdown list, then add your signature from the Insert dropdown list.
Im against picketing, but I dont know how to show it.
bwcc is offline   Reply With Quote
Major Problem: Outlook Exp/MS Outlook Geforce Applications and Operating Systems 14 May 27th, 2005 05:07 AM
MS Outlook Problem ILC Applications and Operating Systems 7 April 29th, 2004 06:41 PM
MS Word Formatting Problem Ximensions Applications and Operating Systems 9 June 25th, 2003 02:19 AM
Outlook problem. NeoStarO1 Technical Support 10 January 17th, 2003 11:16 PM
formatting CAUSED problem joker_927 Applications and Operating Systems 5 December 2nd, 2002 07:43 PM
Is It Just Me? (2955)
Print spooler problem (15)
Open With ..... Win7 (1)
Kingston Bluetooth Dongle Driver (0)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
