Results 1 to 2 of 2
    Senior Member Mombo323's Avatar
    Apr 2005
    Illinois
    557
    problem with hardware
    I have a phillips cd recorder labled as secondary master, and a 52x cd rom labled as secondary slave. I have a 20 gig maxtor hard drive as my primary master, and nothing used for Primary slave. Ive noticed that my crd wont read cd's whenI put them in.. the green light flashes a few times then thats it... nothin. My cd rom also will read some of the files but not all and tends to lock up the computer. I have purchased a brand new cd rw rewriter but have not installed it yet. should it be set at Primary slave or secondary something or other, and if I install this, can I get rid of the 52x cd rom..? i dont need both do I? thanks
    Mar 2002
    Under Your Bed
    8,909
    Set the new burner as secondary master...you don't need two optical drives installed unless you plan on doing a lot of disc-disc burning. You can still do that with one optical drive (your burner), just takes a little longer. Just curious, do either of your current drives work alone as secondary master? Have you double checked your jumper settings? Tried CS for both instead of setting master/slave? It sounds like the drive that won't read CDs at all has the jumper set incorrectly. Does it show up in your device manager?
  1. Problem detecting hardware
    By MaddSeason in forum General Tech Discussion
    Last Post: March 15th, 2005, 02:32 PM
  2. Hardware problem? maybe Software?
    By nisfini in forum General Tech Discussion
    Last Post: January 20th, 2005, 11:23 PM
  3. Hardware Problem...
    By Ecko_Blue in forum Technical Support
    Last Post: October 12th, 2004, 06:38 PM
  4. hardware problem?
    By imt4000 in forum General Tech Discussion
    Last Post: May 16th, 2003, 02:14 PM
  5. [UD] Hardware problem??
    By mickwish in forum Distributed Computing
    Last Post: February 5th, 2002, 06:06 AM
