Sound recorder isn't no where to be found
Currently Active Users: 2156
Discussions: 200,512, Posts: 2,374,433, Members: 245,837
Old February 24th, 2006, 09:04 PM   Digg it!   #1 (permalink)
Question
I cannot find my Sound Recorder anywhere on my screen, the reason for this is because on my family screen I took it off and put it on the deskstop, and when I try to get it on my screen, I can't find it, any help as to why I can't find it?
Evny- ME is offline   Reply With Quote
Old February 24th, 2006, 09:28 PM     #2 (permalink)
Banned
Did you drag the accessories sound recorder icon off of the entertainment list to the desk?
First check the recycle bin to see if someone dragged it there where you can restore it. The
best way to create a desktop icon is not to drag a default system link directly but to create
a second shortcut to the desktop. If it gets deleted you simply create a new one after. Take
a quick look in the entertainment area of accessories if this was an extra shortcut created by the method described here. If it was a software installed you would have to browse the
installation folder for the executable to create another by right clicking on it and then drag
the new shortcut onto the desktop from the explorers window.
PC TECH250 is offline   Reply With Quote
Old February 24th, 2006, 10:19 PM     #3 (permalink)
Well, I looked into my recycle bin and it's not there.
Old February 24th, 2006, 11:05 PM     #4 (permalink)
Banned
If you pulled the link off of the entertainment section right to the desktop and it was wiped
by either dragging to the R.Bin or right clicked to delete and the bin was emptied a reinstall
of the recorder may have to be performed to replace it. If you are currently running XP you
could look into the unused desktop folder to see if desktop cleanup had just been run on an
automatic schedule. If not unchecked that MS background service will run every 30 days. If
you see this folder on the desktop look in there. With multiple user accounts try each one to
see if one there has made created. The last option to simply create a destop shortcut is a
simple browse in the "C:\Windows\system32\" folder to locate the sndrec32.exe file. By the
right click on the executable you can create a new shortcut. That could be used temporarily
until and if? the original is found.
- - Sound Recorder. blueberryhoney Technical Support 3 January 26th, 2006 08:52 PM
Sound recorder MageBeowulf Technical Support 1 May 30th, 2005 10:07 PM
A substitute for Sound Recorder? ArcticFox Multimedia and Audio 5 March 5th, 2005 11:41 AM
Sound Recorder SpaceSquad Multimedia and Audio 16 January 16th, 2005 10:08 AM
Sound Recorder alondra Applications and Operating Systems 10 November 8th, 2002 03:58 PM
Is It Just Me? (1639)
windows 7 retail and rtm (5)
HELP!!! What do you think of this s.. (20)
Review My Build (6)
Assosiations (21500)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
HELP!!! What do you think of this sys.. (20)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
