i have a Pioneer 110D optical drive that started giving me problems tonight...when i put in a disc...either blank or written...or comercially made all it does is the power light flashes a few times on the drive and thats it. if i explore the drive with media in it...it shows up as an empty drive. i have un-installed in device manager and rebooted thinking it was just an error...still the same...don't think it's a loose cable or jumpers as i've not opened my case in a while and it has always worked fine before. do you think my drive has gone belly up on me???....anybody else had a similar problem with an optical drive.
