N2U400-A + NZXT Guardian case problem
Currently Active Users: 1698
Discussions: 200,933, Posts: 2,379,195, Members: 246,298
Old May 8th, 2006, 08:58 PM   Digg it!   #1 (permalink)
SunDizzle's Avatar
Ok it was suggested I start a new thread so here I am. I have this NZXT case (http://www.nzxt.com/products/guardian) and the ECS N2U400-A mobo (http://www.ecs.com.tw/ECSWeb/Product...ID=16&LanID=9).
Now I can't seem to connect the front head phone/mic jack to the mobo since the wire is too short. Is there anything I can do about that or no?
Fill cups like Double D's!!
SunDizzle is offline   Reply With Quote
Old May 8th, 2006, 09:22 PM     #2 (permalink)
_Switch_'s Avatar
er.....stretch it?
but really it shouldnt be too short, but if it is, then there's not rly much u can do unless u can try routing it somewhere else to make it lnoger....
_Switch_ is offline   Reply With Quote
Old May 8th, 2006, 09:25 PM     #3 (permalink)
No pants, Wearin'a Helmet
MitaDC's Avatar
Send a message via ICQ to MitaDC Send a message via MSN to MitaDC Send a message via Yahoo to MitaDC
you any good at soldering? could get some wiring from radio shack and just solder them together and that might work.
Dr. Cox -Newbie, Stay. Oohhh what a good boy you are, Newbie..... DEAR GOD JUDY HOW MUCH PRODUCT DO YOU USE?
J.D -None. It's like this when I wake up
MitaDC is offline   Reply With Quote
Old May 8th, 2006, 09:44 PM     #4 (permalink)
SunDizzle's Avatar
Yeah I thought about the whole soldering thing but then I got worried. I guess I just need the same guage of wire and that should be good, correct? I will try to stretch it but it's almost a full inch that I have to go. I will try that first and let you know but, I might have to go through the whole soldering thing...LOL They don't sell these wires/connectors seperately, right?
Old May 8th, 2006, 10:13 PM     #5 (permalink)
MitaDC's Avatar
I don't know if they have the wires/connectors. If you do go the soldering route, don't worry about getting the same gauge cabling, as long as it is the same gauge or larger it shouldn't matter. Just don't go with 12 gauge wiring
Old May 8th, 2006, 10:18 PM     #6 (permalink)
SunDizzle's Avatar
Will do, just tried to get the cords to stretch (LOL) had to try it... Of course it didn't work I will try the soldering bit this week.
Where do I cut the wire? By the black pin connectors or further down the line towards the jacks?
thanks for the help so far...
Old May 8th, 2006, 10:31 PM     #7 (permalink)
MitaDC's Avatar
I would just cut it off in the middle, give yourself plenty of room to work. Probably closer to the connector if anything because it is easier to get to. Worst thing you could do is cut too far up and maybe break the wire as you are trying to stip it and then not have anywhere to go.
Old May 8th, 2006, 10:34 PM     #8 (permalink)
SunDizzle's Avatar
Good deal, I will try it this week and let you know
Old May 14th, 2006, 03:38 PM     #9 (permalink)
SunDizzle's Avatar
Alright, I actually took an old case power cord and used segments of that. Cut the connectors off the audio cord and soldered the segments in. Taped them all up and plugged them in...they work now !! Thanks to all of you.
One thing though, I had to use the jumpers on the pins still. I still had to short out the front panel return audio pins. I shorted out pins 4,6, and 7.
Thanks again.
Old May 14th, 2006, 10:09 PM     #10 (permalink)
MitaDC's Avatar
glad to hear u got it to work
TechIMO Contest: NZXT Nemesis Elite Case (Times Three!) RobRich IMO Community 356 June 24th, 2006 04:11 PM
n2u400-a + 5.1 = confused Omardeth Motherboards 22 May 9th, 2006 05:11 PM
NZXT Nemesis Case lazyman4444 PC Modification 0 August 27th, 2005 02:21 AM
NZXT Guardian Case ScottyRolen General Tech Discussion 1 November 1st, 2004 03:24 AM
ECS N2U400-A Front242 Technical Support 5 April 26th, 2004 10:41 AM
Is It Just Me? (2887)
Wireless Televisions. (5)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
