GeForce Fx 5500 Problems
Currently Active Users: 2503
Discussions: 201,011, Posts: 2,380,100, Members: 246,377
Old May 29th, 2006, 06:12 PM   Digg it!   #1 (permalink)
ok, i had a old hp about a month ago and my fx 5500 worked fine, but then i finally upgraded to a HP a804n and when i try to install the card it will not work. i disable the onboard, and change the setting in the bios but in the device manager it says the the device will not start(code 10), any idea what is wrong
zimsk8er is offline   Reply With Quote
Old May 29th, 2006, 06:23 PM     #2 (permalink)
(AKA) Nakamura
sweeper2's Avatar
is this a PCI card or a AGP card ... did you uninstall the old drivers for the onboard video... "not sure if it's ATI onboard graphics or nVidea" ..
P4 3.0ghz , P4M900-M4 , 450 psu , Sapphire HD 3850 512mb with an Accelero S1 cooler , 2gig pc5300 ddr2, 80gig Deskstar , 16x dvd-rw
Old May 29th, 2006, 06:27 PM     #3 (permalink)
its nVidia PCI, and i uninstalled the drivers and it didnt work, and it is Intel onboard 82845G
Old May 29th, 2006, 07:01 PM     #4 (permalink)
(AKA) Nakamura
sweeper2's Avatar
code 10 seems to be a "tricky" code.... what operating system are you running..
here is a link to some suggestions... which I found by "Google" ... see what it can do for you...
http://www.hauppauge.co.uk/board/showthread.php?t=123
Old May 29th, 2006, 07:16 PM     #5 (permalink)
windows xp home edition
Old May 29th, 2006, 08:31 PM     #6 (permalink)
does code 10 mean something is wrong with the card, or would i be able to sell it?
Old May 29th, 2006, 08:32 PM     #7 (permalink)
(AKA) Nakamura
sweeper2's Avatar
http://support.microsoft.com/kb/310123
there is another explanation... seems a reg. mix up or something... see if you can do what is said in the above link...
uninstall all display drivers...
reinstall card.. make sure it's all seated correctly etc.. or try a different PCI slot...
then reinstall your display driver , you could possible try and reinstall your "MB" drivers as well.. see if that works...
Old May 29th, 2006, 08:33 PM     #8 (permalink)
(AKA) Nakamura
sweeper2's Avatar
not sure if it's the card or not... you would have to try it in another machine and see if it works...
Old May 30th, 2006, 01:21 PM     #9 (permalink)
Human voltmeter
DanU's Avatar
How did you disable the on-board video? Did you also disable "assign IRQ to VGA"?
Old May 30th, 2006, 07:45 PM     #10 (permalink)
i went into the device manager and disabled it
Geforce 5500 fx gone crazy paulica112 Graphics Cards and Displays 7 April 20th, 2006 01:59 PM
NVidia GeForce 5500 FX heritagius Graphics Cards and Displays 9 August 7th, 2005 10:00 PM
GeForce 5500 256mb PCI card @ Battlefield2 SgtDriggs Graphics Cards and Displays 17 August 4th, 2005 04:05 PM
problem with tv usage on geforce 5500 schmobie Graphics Cards and Displays 0 July 23rd, 2005 10:41 PM
BFG GEforce 5500 fx 256MB noobhere Graphics Cards and Displays 33 May 12th, 2005 12:57 AM
Is It Just Me? (3138)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (6)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Please Help. (1)
winrar decompresses, but video gone (0)
Advice for stopping IRQ BSOD is win7 (0)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
