HP Pavilion ze4900 fan not working! Need Input!
Currently Active Users: 2146
Discussions: 200,948, Posts: 2,379,401, Members: 246,309
Old June 4th, 2006, 06:20 AM   Digg it!   #1 (permalink)
The fan on my pavilion ze4900 isn't working anymore, and I need to replace it ASAP. I just wanted to know if the only thing that will fit is just an original one, or are there better quality ones out there that will fit and work fine? Can anyone give me some suggestions? I am pretty new to fixing computers, although I've replaced my hard drive, dvd-rom and screen already. There is only one fan in this computer, right? Or are there more I don't know about? Thanks in advance!
-Woody
sswoody00 is offline   Reply With Quote
Old June 8th, 2006, 08:42 PM     #2 (permalink)
Nobody knows? Are fans universal, or do I need a specific size, speed, etc.? How do I find out what I can replace it with?
Old June 8th, 2006, 09:16 PM     #3 (permalink)
JLK03F150's Avatar
Send a message via ICQ to JLK03F150
You need to look at the back of your laptop & find the entire model number. There are countless versions (well, 84 of them anyway) of the Pavilion ZE4900. Hopefully there is a service manual that shows you how to take it apart & the fan specs. Let us know what you find out.
Welcome to TechIMO too.
JLK03F150 is offline   Reply With Quote
Old June 9th, 2006, 12:45 AM     #4 (permalink)
Well, it's a ze4910us and I can't find any manuals on that link. It has a part number for the processer cooling fan (if that's what I'm looking for) but it's not available to order. I'm going to try searching online for it.
PC TURNS ON THEN OFF CPU FAN AINT WORKING soundwavesdj87 Technical Support 3 December 13th, 2005 04:05 AM
Fan noise in Hp Pavilion AztekZoul General Tech Discussion 11 December 30th, 2004 01:41 AM
HP Pavilion 734n Recovery not working SteveMon Technical Support 4 June 29th, 2004 12:09 PM
HP pavilion amd duron 850. fan propblem VUK Mobile Computing 2 March 16th, 2004 04:21 AM
re: cpu fan not working edp24 Motherboards 5 March 1st, 2003 02:31 PM
Making Health Care Worse (173)
Is It Just Me? (2936)
The disrespect of Obama by Russian .. (22)
Regular Build (6)
Print spooler problem (15)
How to convert MP3's (4)
Graphics Card Upgrade Question (3)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
