DVD-RW problem
Currently Active Users: 1172
Discussions: 200,929, Posts: 2,379,147, Members: 246,296
Old July 26th, 2006, 03:39 AM   Digg it!   #1 (permalink)
DVD-RW problem
Hello,
I just replaced a CDROM drive with a DVD-RW drive (NEC 3550A). This is the 2nd drive on the system and is operated as slave, the first master drive being a Plextor.
Anyhow, the Plextor lets me access the drive when there's no disc or even a blank disk in there, and copy/paste stuff to the drive to be written. The NEC only lets me access the drive if there's a written CD in there, I can't open up a blank disc and copy stuff to the folder to be written.
Any ideas on why this might be happening? Thanks!
Mark Hayenga is offline   Reply With Quote
Old July 26th, 2006, 03:48 AM     #2 (permalink)
ph34r t3h g04t
Whir's Avatar
Possibly a driver issue. Are you sure Windows is recognizing the drive as a burner?
Old July 26th, 2006, 02:10 PM     #3 (permalink)
Yep, it named it DVD-RW Drive.
Old July 26th, 2006, 02:32 PM     #4 (permalink)
It does let me burn stuff to it with the included software though (Nero).
Old July 26th, 2006, 04:41 PM     #5 (permalink)
sechs's Avatar
I don't use the Windows built-in IMAPI burning software, but I'd guess that it's limited to one drive either generally or because the old drive wasn't a burner.
If it's the latter, then you may be able to fix it by removing both drives and rebooting.
sechs is offline   Reply With Quote
I have a problem with burning a CD/ DVD I have a “Pioneer DVD-RW DVR – K12D”, stdjas Technical Support 3 October 22nd, 2006 03:35 PM
DVD Problem shado b Multimedia and Audio 16 August 12th, 2005 10:50 AM
DVD problem... vikeor General Tech Discussion 2 January 31st, 2005 03:59 PM
Dvd Rw Problem PETEDANIELS Technical Support 2 January 5th, 2005 12:38 PM
dvd problem.... problemchild Technical Support 5 June 11th, 2002 07:01 PM
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
