Thread: Hard drive clicking sound
October 8th, 2006, 01:03 PM #1Member
- Jan 2002
- 283
Hi all
My parents called me over because there computer won't boot. When I try to start it it gets to the Windows splash screen and then it freezes and the hard drive just keeps making a click sound. After awhile like 5-10 minutes it will ask to boot in safe or regular mode while the hard drive still keeps clicking. After awhile I just shut it down. I can get into dos on a boot disk, so I am guessing the drive is not totally done yet? THey told me they ran AVG and when AVG told them to reboot this happened? They are running Win ME
. Any thoughts? Should I try to install Windows again?
Thanks,
Jutah
October 8th, 2006, 01:06 PM #2
That is known as the "click of death".
See if you can keep it (the HDD) running long enough to save their files asap, then replace the drive.
October 8th, 2006, 01:09 PM #3Member
- Jan 2002
- 283
Et Oh. If I put this drive in another machine to try to get its contents off of it will it cause any problems?
Thanks,
Jutah
October 8th, 2006, 01:32 PM #4
I don't think ME will deny access to the My Documents folder when you slave the drive. You should be able to access their files. Programs and OS will need to be installed on the new drive from disk though. Good Luck!
October 8th, 2006, 02:22 PM #5Member
- Jan 2002
- 283
Cool thanks
jutah
My hard drive makes a clicking sound and then my PC hangs all of a sudden...
By Mave Datthews in forum Storage RelatedReplies: 3Last Post: January 12th, 2005, 07:52 AM -
Clicking Hard-drive... bad.
By joker_927 in forum General Tech DiscussionReplies: 7Last Post: August 4th, 2004, 06:59 AM -
Clicking hard drive
By Doot in forum Storage RelatedReplies: 7Last Post: November 11th, 2002, 06:23 PM -
Hard Drive Clicking: Silenced
By claco in forum Mobile ComputingReplies: 12Last Post: October 23rd, 2002, 08:41 AM -
Clicking Hard Drive
By franklin jones in forum Storage RelatedReplies: 7Last Post: April 13th, 2002, 09:29 PM
Great to hear! :)
distro best suited for me? I've...
