October 27th, 2006, 02:34 AM #1Member
- Dec 2005
- 278
Need Help ASAP - Need codec for video conversion????
It says this, and i've downloaded all kinds of codecs, etc, and NOTHING. I leave for a flight in 2 days, and I want to get these videos converted and onto my mp3 player.
Any help would be extremely helpful.it will make all the difference... and you know that.
October 27th, 2006, 02:46 AM #2
Would be more informative to know the source video format and what you want to convert it to...
October 27th, 2006, 03:04 AM #3Member
- Dec 2005
- 278
Both are AVI files, and I want to convert it to whatever will play on my mp3, so I'm lost as to why it isn't working, it has in the past.
October 27th, 2006, 04:47 AM #4
avi is a container not a format
and what MP3 player do you haveHey who turned sigs on?
October 27th, 2006, 11:39 AM #5Member
- Dec 2005
- 278
Ahh. I have a creative zen vision:m. I've put movies on before, but now it's not converting them.
October 27th, 2006, 02:31 PM #6
You need to figure out what CODEC is being used. As headband said, AVI is a "container" that can use any number of codecs. Open the file in windows media player, then go to file >> properties. It should tell you what audio and video codecs it uses. Post back here and let us know.
October 27th, 2006, 03:05 PM #7
Gspot is pretty accurate to provide info about video, audio files..
http://www.headbands.com/gspot/
October 27th, 2006, 06:30 PM #8Member
- Dec 2005
- 278
For the properties it just said the name of the movie.AVI so id unno?
October 27th, 2006, 09:41 PM #9
use gspot it will provide a complete information off the codec screenshot the window and post it back.
October 27th, 2006, 10:03 PM #10
best advice is to check at videohelp.com those guys have loads of info most portable devices are starting to use .3gp files and the program 3gp coverter is by far one of the easiest to use.. you select the device and format then just drag and drop the file you want to convert.. as the guys here have stated though.. best thing to do is to ID what codecs the avi file is using that you're trying to convert.. i'd bet it's xvid using mp3 vbr as the audio codec and that's what's giving it a fit.. best thing for that is gui4ffmpeg covert it w/ it and it should play w/ out a problem
"I play from the heart, when I think about it, it loses its soul.." -The late Stevie Ray Vaughan
Visit MySpace!
Video Codec Help
By frel-dar in forum Applications and Operating SystemsReplies: 3Last Post: May 12th, 2006, 10:38 AM -
New Video Codec?
By ClubMed in forum Multimedia and AudioReplies: 6Last Post: November 4th, 2005, 12:25 PM -
codec for AVG video
By muarrif in forum General Tech DiscussionReplies: 9Last Post: July 2nd, 2005, 07:29 PM -
Need video conversion help...
By Smetana in forum Multimedia and AudioReplies: 2Last Post: May 2nd, 2005, 10:09 PM -
Video trying to use wrong codec
By [Neo770] in forum Multimedia and AudioReplies: 12Last Post: April 22nd, 2004, 05:00 AM
next we will see stories of peoples lights being hacked.
