major XP boot up problem
Currently Active Users: 1628
Discussions: 200,933, Posts: 2,379,180, Members: 246,298
Old November 19th, 2006, 08:48 AM   Digg it!   #1 (permalink)
hi
my brothers PC encountered a problem the other day, when you boot it up it gets as far as the XP loading screen before it says that you cant access the login screen because it cant find shell32.dll and msgina.dll.
i'm not sure what he did to it, i think he was installing a game and it crashed.
i've tried using the original XP disk and botting it up with that in but it wont load up in the recovery mode. i've also tried booting in safe mode, restoring back to previous settings and even downloading the files needed to create an XP boot up disk but i cant get it to work.
i could proberly fix it if i could get to the recovery mode but it wont do that.
can any one help please
stefan099 is offline   Reply With Quote
Old November 19th, 2006, 08:52 AM     #2 (permalink)
cmptrgydv's Avatar
why won't it go in to recovery console
KN1-Extreme
amd althlon64 X2 4800+
2gig DDR400 memory
2 80gig sata drives
radeon X850XT
cmptrgydv is offline   Reply With Quote
Old November 19th, 2006, 08:54 AM     #3 (permalink)
i dont know
i'm assuming you just restart with the disk in and it should go straight to the start up menu ?
Old November 19th, 2006, 09:01 AM     #4 (permalink)
cmptrgydv's Avatar
do you have the bios set to boot from cdrom first?
Old November 19th, 2006, 09:02 AM     #5 (permalink)
i'm not sure how do you do that ?
Old November 19th, 2006, 09:13 AM     #6 (permalink)
cmptrgydv's Avatar
when you start the computer, hit the delete button,
it will go in to the bios, setup, then you can set the first boot device,
what kind of computer is it,
Old November 19th, 2006, 09:23 AM     #7 (permalink)
thanks i'll try that in a moment
its my old computer that was built for me by my dads friend, it still not bad with pentium 4 and an nvidia graphics card
Old November 19th, 2006, 09:33 AM     #8 (permalink)
i've got onto the recovery console
now using some information i've found on these forums i'll see if i can fix it
Old November 19th, 2006, 10:02 AM     #9 (permalink)
right i've made progress
i've followed this method
1. Boot to Recovery Console.
2 . type the following commands
cd system32 [enter]
ren winlogon.exe winlogon.old
ren msgina.dll msgina.old
ren shell32.dll shell32.old
ren shlwapi.dll shlwapi.old
cd.. [enter]
cd servicepackfiles\i386 [enter]
copy MSGINA.DLL c:\windows\system32
copy SHELL32.DLL c:\windows\system32
copy WINLOGON.EXE c:\windows\system32
copy shlwapi.dll c:\windows\system32
if not there, expand from the cd
3 Type EXIT and hit enter
however i've had another problem
when entering ren shell32.dll shell.old it cant find it
but i continued
now when i entered cd servicepackfiles\i386 it says it cant find the directory
am i doing something wrong here ? i'm using the original XP disk
Old November 19th, 2006, 10:16 AM     #10 (permalink)
cmptrgydv's Avatar
where did you get that info from,you need to expand the i386 folder,
so it will look in the folder,
so it would look like this
i386\shell32.dll
major XP boot up problem stefan099 Applications and Operating Systems 3 November 19th, 2006 03:06 PM
CPU will not Boot - Major Problem MyCPUbusted General Tech Discussion 0 August 14th, 2006 12:40 PM
Major Boot Problem - Please help... sarah123 Technical Support 10 July 19th, 2004 10:20 PM
major boot problem on new pc kuby123 Technical Support 12 April 27th, 2004 09:33 PM
Major Problem! Hard Drives wont boot! Redwolf General Tech Discussion 12 January 11th, 2003 10:55 PM
Is It Just Me? (2878)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
Wireless Televisions. (2)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
