Startup Problem*
Currently Active Users: 2139
Discussions: 200,948, Posts: 2,379,382, Members: 246,309
Old December 2nd, 2006, 03:33 PM   Digg it!   #1 (permalink)
Startup Problem*
I woke up this morning to start my computer and I come to find out that, my computer has a startup error. Delightful. Instead of going through the usual Vaio then Ht then my admin screen ( windows xP) it came to this black screen saying that the CMOS loaded abnormal and I believe the chasis fan stopped working. I dont know what happened. I can still load and go to the regular screen despite this but I dont want to keep using my computer and things are fucked up with it. Doesnt the chassis fan have something to do with pushing hot air out ?
ok.player is offline   Reply With Quote
Old December 2nd, 2006, 03:44 PM     #2 (permalink)
Pump you sucker! Pump!
Chuckiechan's Avatar
First of all, clean up your language.
Next, If I understand you all is well and loading correctly except a fan isn't working? Depending on where you live, you should be ok - just leave the case sides off for now, but you need to replace it. And yes most fans blow in or out.
They aren't hard to replace and they aren't expensive. I assume you aren't talking about a laptop are you?
Obama has taken America from purported bully to notorious chump in less than a year.
Chuckiechan is offline   Reply With Quote
XP Startup Problem outofsync Technical Support 1 January 28th, 2006 05:01 PM
Startup problem. help!!!!! Hamza General Tech Discussion 2 October 22nd, 2005 12:22 PM
Problem at startup merajahmed Applications and Operating Systems 1 October 29th, 2004 08:24 AM
Startup problem thutchguru Motherboards 3 August 27th, 2004 07:50 PM
startup problem wah Applications and Operating Systems 4 June 14th, 2003 08:33 PM
Making Health Care Worse (168)
The disrespect of Obama by Russian .. (19)
Is It Just Me? (2934)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Internet Lost (0)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
