problem with custom computer
Currently Active Users: 2315
Discussions: 200,943, Posts: 2,379,283, Members: 246,305
Old December 29th, 2006, 09:35 PM   Digg it!   #1 (permalink)
Milwaukee's Avatar
I got all new computer it
Intel Pentuim D 820
512 mb ddr2
WD Sata 80 GB
ESC motherboard http://www.newegg.com/Product/Produc...82E16813135023
It will turn on and I see monitors show gray screen but when on or off it shake so I try set but not success. I want use VGA instead graphic card.
I try different rams, reset cmos, remove battery but not success.
I think it must be motherboard must be bad but it turn on but won't show on monitors.
I want use this by tomorrow.
sorry for my bad grammar!
Milwaukee is offline   Reply With Quote
Old December 30th, 2006, 01:26 AM     #2 (permalink)
Banned
with onboard vga you change setting in the bios setup from agp or pci-e to onboard and plug monitor into vga port.
caveminder is offline   Reply With Quote
Old December 30th, 2006, 01:32 AM     #3 (permalink)
Milwaukee's Avatar
Fix it. I didn't see 4 pin near to CPU was another power plug so it was different because most I work on old motherboards. Now it boot up then install window xp home
Old December 30th, 2006, 09:29 AM     #4 (permalink)
Caveat Emptor
Rootstonian's Avatar
Different thread, but you were there too...sometimes people just don't spend 5 minutes searching this wonderful forum for advice
Computer turns on but does not boot
Problem Loading custom maps in BF2! Eagle19 General Gaming Discussion 1 June 26th, 2008 03:40 AM
Got free custom computer! Milwaukee General Tech Discussion 20 December 14th, 2006 04:12 PM
My computer buildup and custom water cooled case mods with tons o pics mypartsguy PC Modification 11 February 25th, 2005 10:41 PM
Computer Diagnostic Software (Computer lock up Problem) Fujiiro Applications and Operating Systems 9 July 29th, 2002 09:30 AM
Custom Computer Deal Yankees4 ResellerRatings Homepage Deals 9 April 23rd, 2002 06:51 PM
Is It Just Me? (2916)
Wireless Televisions. (9)
Regular Build (6)
cheap AF1,AF1XXV,gucci,jeans,belt,bra.. (0)
Asus P4G8X Mobo (4)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
