External Harddrive Problem...
Currently Active Users: 2707
Discussions: 201,000, Posts: 2,380,036, Members: 246,369
Old March 17th, 2007, 08:56 PM   Digg it!   #1 (permalink)
Christato's Avatar
Send a message via ICQ to Christato Send a message via AIM to Christato Send a message via MSN to Christato Send a message via Yahoo to Christato Send a message via Skype™ to Christato
Angry
Hey Guys,
My Dad and I bought a External Harddrive Enclouser (http://www.newegg.com/Product/Produc...82E16817113007) we put one of our old Windows 98 Harddrives in it, when we plugged it in to his computer the light turned on, the harddrive started up, and the bubble on the taskbar said "Installation Failed"!. I posted here before and you guys said it would work (Make My Own External Harddrive?.
I NEED HELP!
-Chris
Christato is offline   Reply With Quote
Old March 18th, 2007, 08:41 AM     #2 (permalink)
Christato's Avatar
plz help
Old March 18th, 2007, 08:45 AM     #3 (permalink)
muarrif's Avatar
Send a message via MSN to muarrif Send a message via Yahoo to muarrif Send a message via Skype™ to muarrif
Question
Was it working in previous setup
Is it formated ?
i.e. did you format the drive before taking it out of the previous computer? IDE
muarrif is offline   Reply With Quote
Old March 18th, 2007, 08:47 AM     #4 (permalink)
Christato's Avatar
well the problem is that we can't because the computer we took it out of is dead
Old March 18th, 2007, 08:53 AM     #5 (permalink)
muarrif's Avatar
Arrow
So it is a possiblity that the drive may have died with the computer?
However things to check:
  • Do you have USB1.1 or USB 2.0 in the new computer that you are trying to use this drive with?
  • Can you possibly connect the hard drive (without enclosure) as a second drive to your PC IDE and format it?
  • What are the jumper settings? i.e. Cable Select (CS), Master (MA) or Slave (SL)?
  • Check if power is connected to the drive (internal connector as well as external check)
Old March 18th, 2007, 08:58 AM     #6 (permalink)
Onii-san
Bizkitkid2001's Avatar
If the hard drive was pulled from a name brand computer (Dell, Compaq, Gateway, ect...) it most likely has a system identifier code on it that prevents the hard drive from working in a different computer to avoid people stealing the OEM Windows installation. The only way to get around this is to format the drive which would delete the code.
However, the drive should AT LEAST show up under disk management, however it will not be shown as a bootable or working partition.
Bizkitkid2001 is online now   Reply With Quote
Old March 18th, 2007, 11:11 AM     #7 (permalink)
Christato's Avatar
The drive is not appearting under Disk Management nor is is showing up as a removeable drive in "My Computer." However, the icon for "Safe Removal of Hardware appears in the taskbar. It was originally formatted under Windows 98SE and the system I am trying to use it with is running XP. What should the jumper settings be set at? Any other suggestions?
Old March 18th, 2007, 01:16 PM     #8 (permalink)
Christato's Avatar
anyone there?
Old March 18th, 2007, 03:53 PM     #9 (permalink)
Ol'Tunzafun's Avatar
Jumper should be set to Master or Single (no slave).
Check the connections.
You can always try installing it into your XP system. That way you'll at least know where the problem lies.
Ol'Tunzafun is offline   Reply With Quote
Make My Own External Harddrive? Christato Technical Support 11 March 11th, 2007 05:19 PM
Suitable external harddrive size J1mmy Storage Related 1 October 18th, 2006 07:15 AM
Usb 2.0 external harddrive randomly disconnects p3t3r1 Storage Related 1 August 8th, 2006 03:42 PM
My external usb harddrive won't read hatehotmail Technical Support 7 November 2nd, 2005 11:15 AM
Maxtor 250 External Harddrive Problems gmcilvee General Tech Discussion 9 March 13th, 2005 07:04 AM
Is It Just Me? (3122)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Laptop with wireless problem. (13)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
